Axle taper
SteveD
First Name: steven
Last Name: davidson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Axle taper
Post by SteveD » Wed Sep 13, 2023 12:38 pm
Can someone tell me the taper on the end of an axle?
George Mills
Last Name: Mills
Re: Axle taper
Post by George Mills » Wed Sep 13, 2023 12:58 pm
maybe this helps?
jab35
Last Name: Bartsch
Re: Axle taper
Post by jab35 » Wed Sep 13, 2023 2:45 pm
This post mentions a taper of 1.5 inches/foot.
https://www.mtfca.com/discus/messages/2 ... 0tolerance.
For the dimensions shown in the drawing in this post, the taper is 3.546 degrees
A 1.5 inch change in diameter per foot of length gives a taper angle of 3.576 degrees
Respectfully, jb
First Name: john
Last Name: karvaly
Re: Axle taper
Post by speedytinc » Wed Sep 13, 2023 3:39 pm
A little trig work, I come up with 3 degrees 15 minutes. Or 3.25 degrees/side. 6.5 degrees total
Re: Axle taper
Post by DanTreace » Wed Sep 13, 2023 5:32 pm
1 1/2" per foot. Ford axle drawing.
SteveD
First Name: steven
Last Name: davidson
Re: Axle taper
Post by SteveD » Wed Sep 13, 2023 8:30 pm
Thanks guys
