Axle taper
Topic author - Posts: 111
- First Name: steven
- Last Name: davidson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Axle taper
Can someone tell me the taper on the end of an axle?
- Last Name: Mills
Re: Axle taper
maybe this helps?
- Last Name: Bartsch
Re: Axle taper
This post mentions a taper of 1.5 inches/foot.
https://www.mtfca.com/discus/messages/2 ... 0tolerance.
For the dimensions shown in the drawing in this post, the taper is 3.546 degrees
A 1.5 inch change in diameter per foot of length gives a taper angle of 3.576 degrees
Respectfully, jb
Respectfully, jb
Re: Axle taper
A little trig work, I come up with 3 degrees 15 minutes. Or 3.25 degrees/side. 6.5 degrees total
Re: Axle taper
1 1/2" per foot. Ford axle drawing.
Re: Axle taper
Thanks guys
