13/14 Runabout Tack Rail Wood
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Wed Sep 13, 2023 1:37 pm
Is anyone selling new Tack Rail Wood for a 1914 Runabout??
If not, does anyone have a set of patterns I can purchase for making one??
Last Name: Hatch
Re: 13/14 Runabout Tack Rail Wood
Post by Dan Hatch » Wed Sep 13, 2023 2:27 pm
Is this the piece around the back of seat? If so look into the plastic strips sold my Langs. Dan
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Wed Sep 13, 2023 3:39 pm
Yes Dan, it is the piece around the backside of the body. I need to replace it when I sew the seat covers, but I don't want to make patterns and shape wood plus the sewing when I down the car. Do you think those pieces of plastic are as strong as what hardwood would be when it comes to providing body rigidity?
Last Name: Tannehill
Post by JTT3 » Wed Sep 13, 2023 4:22 pm
Brent they work well just heat them with a high wattage heat gun and bend to fit then secure them in place. Best John
Post by Allan » Wed Sep 13, 2023 5:28 pm
The plastic stuff is easy to form and fit, takes tacks well, but in its nature, it is resilient and flexible, so does not add any strength to the seat back assembly. I laminate the rails in strips of 3 ply, using the body panels as the former. You get a much firmer backrest.
Hope this helps, Allan from down under.
Post by DanTreace » Wed Sep 13, 2023 7:17 pm
Believe Classic Wood Products in Greensboro NC sells wood tack strips for Ts.
ricky@classicwoodproductsllc.com
John Anderson also lists '12 to later tack strips in his catalog. Had some tack strips at Luray Swap.
Last Name: Hatch
Post by Dan Hatch » Fri Sep 15, 2023 4:02 am
Have not used the plastic, just delivered a truck load to Langs. Stuff is heavy and it did not bend very easy cold. Dan
MWalker
Last Name: Walker
Post by MWalker » Fri Sep 15, 2023 8:38 am
I have used the plastic ones with good results. As John says above, use a heat gun to soften it as you go. It works great and holds nails well.
