1912 Heinze coils
rnwilliams
First Name: Ricky
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 12 Com. Rdstr, 12 Delivery, 2-12 Tou, 15 Tou, 21 Cpe, 25 Cpe 25 TT, 26 TT, 27TT, 26 PU, 26 Tou, 2-26 4dr, 26 Del, 27 4dr
1912 Heinze coils
Post by rnwilliams » Tue Sep 19, 2023 11:35 am
Could someone please share with me the dimensions of a 1912 Heinze coil w x d x h and the dimensions of the inside of an original Heinze coil box. I have a coil box that appears to be a reproduction Heinze box with no coils. Just not sure if it was made for Heinze coils to fit in. I know the contacts for a ford or KW coil does not line up. Thanks for the help.
Richard Williams, Humboldt, TN
President, Tennessee T's inc.
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Re: 1912 Heinze coils
Post by michaelb2296 » Wed Sep 20, 2023 2:20 pm
2-5/16” X 3-1/16” X 5”
Spool is 2” X 3-7/8” - 8 sections. 5/16” wide. With 7/8” hole down middle.
Wood is 1/4” thick on each side except where it goes down to
1/8” thick where the coil resides.
rnwilliams
First Name: Ricky
Last Name: Williams
Post by rnwilliams » Wed Sep 20, 2023 3:12 pm
Thank you Michael for taking the time.
michaelb2296
First Name: Michael
Last Name: Bunner
Post by michaelb2296 » Wed Sep 20, 2023 3:24 pm
You’re Welcome! As you can see they drilled the column for the coil after the box was assembled. They didnt drill all the way through either! They stopped about 1/2” shy of the bottom!
Notice the lip!
Bill Everett
First Name: Bill
Last Name: Everett
Board Member Since: 2011
Post by Bill Everett » Sun Sep 24, 2023 11:17 am
E-mail with photos sent on 9-21-23.
