26-27 accessory tail light wiring and switch
Will Brown
First Name: Will
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 26 Runabout
Post by Will Brown » Mon Oct 02, 2023 12:05 pm
I have the accessory tail light and license plate bracket which I would like to install/. I need the switch that attaches to the brake pedal. How can I make one? Also how is it wired?
Re: 26-27 accessory tail light wiring and switch
Post by speedytinc » Mon Oct 02, 2023 12:12 pm
Correct repop style attaches on the Bendix cover. Langs #3158XS
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Oct 02, 2023 12:48 pm
Easy to run a wire from the starter switch to the brake light switch, then a wire from the stop light switch following the tail light wire back to the stop light
Will Brown
First Name: Will
Last Name: Brown
Post by Will Brown » Mon Oct 02, 2023 12:54 pm
Thank you. I didn't know that Lang's had the switch.
Post by Mark Gregush » Mon Oct 02, 2023 1:32 pm
A few use the 1928/29 Model A brake light switch mounted under the bottom band inspection plate screw with a bent wire connecting it to the brake pedal.
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Post by kmatt2 » Mon Oct 02, 2023 2:13 pm
Besides the options above there is the option of using the lever type brake lite switch as used on a 1949-50 Chevrolet. Mount it such that the forward motion of the brake pedal depresses the lever attached to the under side of the floor board or a homemade bracket. If you go with this switch you can buy a new switch from The Filling Station in Lebanon Oregon.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon Oct 02, 2023 4:31 pm
I think Snyder's and possibly Chaffin's has it too. The repos made years ago, gave a lot of trouble. I understand that the current ones are made in USA and are of better quality.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Mon Oct 02, 2023 6:18 pm
You can also check with Birdhaven to see if they are making the Fun Projects switch. It is really easy to install and reliable.
1926 Tudor
Post by TRDxB2 » Tue Oct 03, 2023 1:29 pm
Many variations & ideas viz Google search https://www.google.com/search?client=fi ... RJXYGWCXNM
