Cam nut wrench!
Les Schubert
Topic author - Posts: 1360
- First Name: Les
- Last Name: Schubert
Cam nut wrench!
I’m wondering if there is a dozen people who would be interested in buying one. It’s a special “box end” with a 1/2” offset of the handle. Thinking about making some. They would be CNC cut and have about a 10” handle.
- Last Name: Tannehill
Re: Cam nut wrench!
I’m a fool for tools
Les Schubert
- First Name: Les
Re: Cam nut wrench!
Thank you John
TLeroux
- First Name: Tom
- Last Name: Leroux
- Board Member Since: 2010
Re: Cam nut wrench!
i will take one
tom leroux
tom leroux
JBog
- First Name: Jason
- Last Name: Bogstie
Re: Cam nut wrench!
I'm interested.
Re: Cam nut wrench!
Les, the less offset in the handle the better. The original open end Ford wrench for the purpose has an offset of around one inch, so the tool easily cranks off the nut before the nut is brought to a reasonable tension. When I use mine, I have a sleeve to go over the cam snout to engage on the wrench end, a washer to blank off the outer end of the sleeve, and a spare timer nut to hold the wrench, sleeve and washer to stop the wrench crankoing off the cam nut.
TrentB
- First Name: Trent
- Last Name: Boggess
Re: Cam nut wrench!
Like every other Stevens tool I have ever run across, the T-138 Camshaft Nut Wrench works very well.
Respectfully submitted,
Trent
Trent
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: Cam nut wrench!
I bought a cam nut socket from Snyder. It works good and also works quite well on the front wheel bearing.
Andy
Andy
Glenn French
- First Name: Glenn
- Last Name: French
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1926 Fordor
Re: Cam nut wrench!
I am interested in one.
Glenn French
Glenn French
Les Schubert
- First Name: Les
Re: Cam nut wrench!
I will make one and post a picture and a price. Then you can decide.
The idea of using a spacer washer and a timer nut with it sounds like a good idea!
Re: Cam nut wrench!
A friend just uses a Model A spark plug wrench, bend in handle works ok. But a specialized tool would be likely best.
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Re: Cam nut wrench!
A Snap-On 36-F socket is the correct tool.
Or one can be made from a front wheel bearing wrench
(cut from a hubcap wrench multi-tool),
a piece of tubing and an old socket.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Les Schubert
- First Name: Les
Re: Cam nut wrench!
I am looking to make this into a double purpose tool.
One end will fit the cam nut AND the front wheel bearing. On the other end it will fit the front wheel bearing jam nut!
I think that they will probably cost about $20.00.
AndyClary
- Last Name: Clary
Re: Cam nut wrench!
I made a front bearing socket out of a socket because you can’t use the ford wrench with buffalo hubs. I just milled a close enough form in the ratchet side since there’s no real torque on the bearing.
Andy
Andy
Tmooreheadf
- First Name: Tom
- Last Name: Moorehead
Re: Cam nut wrench!
I’d be interested in at least one maybe two!
Tmooreheadf
- First Name: Tom
Re: Cam nut wrench!
A couple of buddies want one so that’s two more for me! Total of 4.
Bob in ohio
- First Name: Bob
- Last Name: Gairing
Re: Cam nut wrench!
I would like to purchase one.
CDooREDW
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: Cam nut wrench!
I believe I’d throw in for one as well!
Thanks,
Ron in HSV
Thanks,
Ron in HSV
Randall strickland
- First Name: Randall
- Last Name: Strickland
Re: Cam nut wrench!
I'll take one
Les Schubert
- First Name: Les
Re: Cam nut wrench!
I picked up the cutout wrenches and now to bend them!!
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: Cam nut wrench!
I'm interested as well
OilyBill
- First Name: William
- Last Name: May
Re: Cam nut wrench!
I'll take one as well! Thanks!
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Re: Cam nut wrench!
Hi Les, I will take 3 of the wrenches. One for me and gifts for two good friends!! Mike Lebsack
havnfun
- First Name: Joe
- Last Name: Kowalczyk
Re: Cam nut wrench!
Hi Les,
The double purpose wrench sounds fantastic, I would like buy two
Regards,
Randy SR
- Last Name: Schultz-Rathbun
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster pickup
Re: Cam nut wrench!
I will buy one as well, sounds like an awesome tool!
Les Schubert
- First Name: Les
Re: Cam nut wrench!
The first one!
17 more soon!
17 more soon!
- Attachments
- IMG_4387.jpeg (19.7 KiB) Viewed 7325 times
Les Schubert
- First Name: Les
Re: Cam nut wrench!
My “Guesstimate” on the cost was “OPTIMISTIC”!!
About $40.00!
About $40.00!
Mike Lebsack-Iowa
- First Name: Mike
Re: Cam nut wrench!
Thanks, I am still down for 3 Les. Mike
Les Schubert
- First Name: Les
Re: Cam nut wrench!
Update
Well I have 18 of these finished BUT now I find that while they fit most cam nuts perfectly I encountered one this morning that it won’t fit!! ARRGH!!
I’m not sure what to do!! I don’t want to sell something that doesn’t fit properly.
Les Schubert
- First Name: Les
Re: Cam nut wrench!
I have now tested the wrench on 15 nuts (including a new repo one) and only one didn’t it fit. So if you are still interested I am prepared to sell them!!
havnfun
- First Name: Joe
Re: Cam nut wrench!
Les, I’ll honor my order of two, I sent you an email
Regards,
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Re: Cam nut wrench!
I’m good at $40 as well
CDooREDW
- First Name: Ron
- Last Name: Wenzel
Re: Cam nut wrench!
Still in for one, Les. You can’t ever have too many tools.
Tnx,
Ron
Tnx,
Ron
TLeroux
- First Name: Tom
- Last Name: Leroux
Re: Cam nut wrench!
I WILL TAKE ONE AT NEW PRICE'
TOM
TOM
Bob in ohio
- First Name: Bob
Re: Cam nut wrench!
I would still like to buy a wrench. Please post payment instructions.
Bob
Bob
Randall strickland
Re: Cam nut wrench!
i'm still in
Bill Anziani
- First Name: Bill
Re: Cam nut wrench!
I'm still interested as well
Les Schubert
- First Name: Les
Re: Cam nut wrench!
I live in Canada
To keep the shipping costs down I have bulk shipped a dozen wrenches to Mike Lebsack in Iowa. He should have them in about a week
Thank you all for your support and interest
Les
Les
Glenn French
- First Name: Glenn
- Last Name: French
Re: Cam nut wrench!
I am still in for one at the new price.
Glenn French
Glenn French
