What are these called? Available?
Bobbbenner
First Name: Bob
Last Name: Benner
* REQUIRED* Type and Year of Model Ts owned: TT 1924, touring 22
Post by Bobbbenner » Sat May 25, 2019 12:38 pm
Below find two pictures of interior metal work on either side of the cab on the floor. What are they called where can I get them. They are in a model TT
Last Name: Strange
Re: What are these called? Available?
Post by CudaMan » Sat May 25, 2019 1:05 pm
These are close, but appear to be missing the tabs for holding the footwell trim panels. Did TTs even have footwell trim panels?
https://www.modeltford.com/item/STT209.aspx
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat May 25, 2019 1:24 pm
You have a excellent example. Making a fix for the rusted side should only be 1-2 hours work would be a good learning experience. Properly done the repairs would be invisible
Post by Rich Eagle » Sat May 25, 2019 1:42 pm
I believe those are the floorboard risers for a '24-'25 Coupe or Tudor. Part No.s 17354X and 17355X. There are many around among closed car restorers. Some even have the vehicle identification number stamped into them.
Post by Original Smith » Sun May 26, 2019 11:07 am
1925 open cars have those tabs too. They don't usually need bending.
Last Name: House
Post by George House » Sun May 26, 2019 9:10 pm
Bob,
Are those floorboard risers on a TT Enclosed Cab ? I looked into my TT C Cab and the floorboard risers were different than your pics. I have a pair hanging in the barn but I’m afraid they’re for an open T. But I do believe the previous advice is correct. It should be a fun few hours with a minimum of metal working tools to repair these examples.
Marv K
First Name: Marv
Last Name: Konrad
* REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
Board Member Since: 2010
Post by Marv K » Sun May 26, 2019 9:34 pm
-Bob-
From memory on our TT, those look just like the 'toe-riser' panels where the sections of floorboards fit in. Our floorboards are also complete originals. I've not needed to replace, so don't know if there is a vendor who has them. If you need pictures, I can go to the shop tomorrow and send pics to you.
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
Post by Rich Eagle » Mon May 27, 2019 11:51 am
For those not convinced or that haven't seen one, this is a '24-'25 Coupe or Tudor. Part No 17355X as mentioned earlier. That is exactly what that cowl is and not a TT cowl. A cut-off Coupe or Sedan.
mvweaver
First Name: Matthew
Last Name: Weaver
* REQUIRED* Type and Year of Model Ts owned: 27 Model TT flatbed and 27 Model TT dump
Post by mvweaver » Fri May 31, 2019 11:49 am
I agree, It's not a TT cowl because they don't have wood trim around the inside of the door opening. It's all steel.
