Champion 30 brass top plugs
Roger Byrne
Topic author - Posts: 76
- First Name: Roger
- Last Name: Byrne
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
Is anybody running Champion 30 Brass Top plugs in their cars? How are they working out?
Preserving Mechanical History for Future Generations since 1965
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Champion 30 brass top plugs
Never saw a Champion 30 before, please post a picture.
Roger Byrne
- First Name: Roger
- Last Name: Byrne
Here is what they look like. The same as the regular T plug but a bit shorter.
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
Not for T. That doesn't appear to be a pipe thread, and the plug washer included indicates the plug is intended to be run down on it to the shoulder on the hex.
Get a horse !
Roger Byrne
- First Name: Roger
- Last Name: Byrne
Rich, at first that is what I was thinking. However it is the standard tapered pipe thread and mic's with the same taper on the top and bottom of the threads as the standard T plug. It is not undercut above the threads so I can't see how that ring would ever seat. When installed in the head, it tightens at the same depth as a regular T plug and compared to the standard X body which protrudes into the combustion chamber about 1/4 inch, this plug body extends only about 1/16". The electrode does extend passed the body (see photo) so it is well into the combustion chamber.
Rich P. Bingham
- First Name: Rich
That's interesting, Roger ! Thanks for explaining. With a pipe thread, should work in a T, the only sensitive issue being the amount it intrudes into the combustion chamber. Guve them a try and let us know !
Useless factoid for the day - the small one-lung gas engine Maytag provided to power their early square tub grey machines in the model T era also used a Champion plug with a 1/2" pipe thread. When these were still around, I remember seeing them running a model T champion "X" plug ! I doubt if many Ts ever ran on the Maytag plug ! But it could have been done !
Get a horse !
