Fordite steering wheel finish?
Steve1920
First Name: Steven
Last Name: Grant
* REQUIRED* Type and Year of Model Ts owned: 1920 Open Express, 1922 Centerdoor, 1924 Coupe
Post by Steve1920 » Sun Oct 29, 2023 10:17 pm
Greetings,
I'm in the process of sprucing up my steering wheel. The spider has been cleaned up and painted and now it's time for the wheel itself. It did not have the smoothest finish to start with, so I cleaned it up and finished smoothing it with fine Scotchbrite. It looks great, has a dull gray finish to it, and I'm not opposed to leaving it like that, but is that what it's supposed to look like?
What was Henry's original finish for them? Was the entire wheel assembly painted black back then? And if painting is the next step, is there a certain paint I should be looking for?
Looking forward to hearing what others have done.
Thanks.
Steve
Last Name: Hjortnaes
Re: Fordite steering wheel finish?
Post by DHort » Sun Oct 29, 2023 11:13 pm
I just waxed mine. I am sorry I do not recall what wax I used. Johnson's paste was should work fine.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Sun Oct 29, 2023 11:45 pm
I got tired of my hands being black after going for a ride so I scrubbed it down about the same as you did and before reassembling it to the spider I gave it several coats of rattle can satin clear coat. It's been about three years and 3,000 miles now and no black residue so far. Jim
tselliott
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Post by tselliott » Mon Oct 30, 2023 12:38 am
I sand them down progressing to finer and finer sandpaper then polish them on my buffing wheel. I think they come out better than painting them.
Steve1920
First Name: Steven
Last Name: Grant
Post by Steve1920 » Mon Oct 30, 2023 12:48 am
Soiled hands after use would have been my next question! Mine were okay handling it after wiping it down after the sanding, but I wondered if actual driving would eventually dirty up the hands.
Did the clearcoat darken down the wheel any, making it appear more black than gray? Or did the gray appearance remain?
Post by TRDxB2 » Mon Oct 30, 2023 12:58 am
jab35
Last Name: Bartsch
Post by jab35 » Mon Oct 30, 2023 2:27 am
I did satin clearcoat like Jim described, did it years ago & sanded to 320 before coating, coating made it appear black. If you remove rim be sure to use correct stainless steel 'Fordite' screws to attach it to the spider or you risk a break. Respectfully, jb
Post by Jerry VanOoteghem » Mon Oct 30, 2023 6:19 am
They only get sticky and blacken your hands when they get wet.
Post by John kuehn » Mon Oct 30, 2023 10:17 am
A few years ago someone was making a reproduction black T wheel. It was just the black ring. It got some good reviews. Anybody know what they were made of?
jab35
Last Name: Bartsch
Post by jab35 » Mon Oct 30, 2023 10:52 am
John: From an earlier post,
https://www.mtfca.com/discus/messages/4 ... 1416837864
By Dan Treace, North FL on Sunday, November 23, 2014 - 04:14 pm:
As for the spider arms. They are pressed steel and can be pressed flat on a flat surface. Just did that for a 17" spider I found and cleaned and painted. The rim from another 17" was fine and in good shape, they are hard to come by lately.
However, that 16" rim you have, made of Fordite, is just not able to be straighted again.
Sorry :-( But too much age and hardening.
Many times the larger Improved Car 17" rims become egg-shaped or oval too. No luck to fix that. Same with the 16" in my picture.
But, Bob's Antique Auto Parts has made new rims for the 16" and in ABS plastic, cost only $50 are terrific replacement.
Post by TRDxB2 » Mon Oct 30, 2023 11:24 am
From two earlier posts above https://www.mtfca.com/discus/messages/1 ... 1292601172
from another
Post by John kuehn » Mon Oct 30, 2023 11:56 am
https://www.modeltford.com/item/3501BL.aspx
New reproduction wheel from Langs
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Mon Oct 30, 2023 1:08 pm
Painted mine black so my hands wouldn't be.
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Post by Original Smith » Wed Nov 01, 2023 12:08 pm
I wax mine, and always wear gloves.
Steve1920
First Name: Steven
Last Name: Grant
Post by Steve1920 » Wed Nov 01, 2023 12:41 pm
I will probably just go with the satin spray finish. The buffing and polish method looks great, though!
My trouble with that method is that the steering wheel would then look way better than the rest of the car!
Thanks for all the replies.
Steve
Post by John kuehn » Wed Nov 01, 2023 1:08 pm
A question would be if the original fordite wheels over time began to sort of deteriorate or if it was always a concern when they were new in the teens and twenties.
Maybe Ford had a steering wheel cleaner sold at the dealers? It would seem that Ford wouldn’t want new owners to have dirty hands after a while. And especially women drivers wearing white gloves!
