Pesky oil leaks
Topic author - Posts: 274
- First Name: Brooks
- Last Name: Schlieben
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT
Pesky oil leaks
I'm addressing several pesky oil leaks. One in particular is on the right, near rear side of the hogs head. Short of pulling it and replacing with a new gasket, what should I use in terms of a sealant? Many thanks for any reply.
- First Name: Susanne
- Last Name: Rohner
Re: Pesky oil leaks
Since you have to pull the hogshead to use whatever sealant, you may as well put the correct gasket there instead while it's off. And while it's off, you can figure out why it's leaking from that spot - I know T's mark their spots, but that's an unusual place to have an oil leak...
Re: Pesky oil leaks
Seal the valve cover hole & engine block around where the throttle rod goes thru. (if you have a single valve cover door)
Put a shop-vac hose into the oil filler.
Spray some brake cleaner around the suspected leak. The brake cleaner will pull into the hole & clean off the oil.
Squirt a bead of ultra black in & around the hole. Let it suck enough into the hole to seal. Shut off the vacuum & let the silicone set over night.
No need to pull the HH & have the same leak or worse on the next attempt to seal.
Re: Pesky oil leaks
Is it possible to take a picture of the area where it leaks? Right rear of hogs head is very close to the Universal joint and could be coming from that area.
Re: Pesky oil leaks
Thanks for the replies.
Will post a pic of the area tomorrow morning.
Re: Pesky oil leaks
Here’s some new T’s in 1927 doing their thing in a Ford showroom. I guess it was expected.
Re: Pesky oil leaks
Leaking, (self chassis lubricating) is built into the design & has gotten worse with wear.
It is controllable to completely stoppable via modern seals & sealers.
My most recent motor doesnt leak a drop. We shall see how long this lasts.
Re: Pesky oil leaks
- First Name: DAN
- Last Name: MCEACHERN
Re: Pesky oil leaks
Believe what John posted above regarding using the shop vac. I told a friend about John's method and he had 100% success using it to stop a huge hogshead leak. Key is to get everything as clean as possible 1st. Joe says thanks John!!
Re: Pesky oil leaks
Glad others are able to use this trick passed to me from an old friend.
I have used this method to chase leaks on a very poorly assembled motor/transmission. After 4 days/sessions the gasket leaks were ALL gone.
Pedal shafts are another matter requiring a lot more & different kind of work.
Re: Pesky oil leaks
I chased an oil leak down near both lower corners of the hogshead - turns out someone previously had used too long of bolts on the field coil mounting holes down on both bottom block holes and just "cracked" through the casting - copious amount of Brakleen then black RTV and bye-bye oil leak !
Re: Pesky oil leaks
Never use a flammable solvent around a shop vac.
Re: Pesky oil leaks
Did some looking around this morning.
Since oil doesn't run up, it has to run down.
Looks like the screws affixing the transmission inspection cover were loose, particularly the corner where the offending oil drip was coming.
(Keep in mind the other day, I was viewing the leak from underneath the TT)
With the floorboard lifted off, I could see the oil path.
Tightened screws.
I do have a gasket in there.
This should do it.
Will start up on Saturday morning. Many thanks for the helpful comments.
Tightened screws.
This should do it.
Re: Pesky oil leaks
BTW, your transmission cover is upside down. V goes down to drip on the band centers.
N/A if you have a screen.
- First Name: Adam
- Last Name: Doleshal
Re: Pesky oil leaks
speedytinc wrote: ↑Wed Nov 01, 2023 10:26 amBTW, your transmission cover is upside down. V goes down to drip on the band centers.
…And that’s probably why it doesn’t seal good. It doesn’t seat properly against the hogshead.
Re: Pesky oil leaks
That inspection plate is easy to remove. Just 6 screws. A little sealer on top of the hogs head then a new gasket with no sealer on top of the gasket. Turn the plate over so the V is down and tighten. Start with the two center screws and then the outer screws later. After you tighten all 6 of them start again and tighten as tight as you can with the screw driver but not enough to strip the threads or break the screws. Should be good. Since you have already tightened the screws, you could try it as is and maybe not need to replace the gasket at this time.
Re: Pesky oil leaks
Wow! Many thanks!
