I have a 1916 Touring with a 21-22 motor with generator and starter. What does the trans/engine weigh? What would you recommend to carry engine after removal from chassis?
Thanks,
Campbell Tellman II
Beaufort, NC
Engine weight
Topic author - Posts: 58
- First Name: Campbell
- Last Name: Tellman
- * REQUIRED* Type and Year of Model Ts owned: 1916 Ford Touring
- Last Name: House
Re: Engine weight
Joe Bell says 550 lbs. others have suggested anywhere from 410-475 lbs. estimates include starter and generator. Recommend to carry engine after frame removal ?? NFL Defensive lineman or 2 ton hoist….
Re: Engine weight
I mount the engine, less starter on an engine stand. Set the transmission end down to keep the weight low. I tear down the engine from it.
Sometimes I use a modified shopping cart. Basket removed.
- First Name: Neal
- Last Name: Willford
Re: Engine weight
My recollection from previous posts is that the 550 lb weight is on a pallet, and possibly with a starter, generator and manifolds
- Last Name: Wrenn
Re: Engine weight
Something like this works real well for me. Stole the idea/dimensions from Joe Bell!Campbell Tellman wrote: ↑Wed Nov 01, 2023 3:44 pmI have a 1916 Touring with a 21-22 motor with generator and starter. What does the trans/engine weigh? What would you recommend to carry engine after removal from chassis?
Thanks,
Campbell Tellman II
Beaufort, NC
Re: Engine weight
A couple of old links stated actuals
550 lbs on a skid https://www.mtfca.com/discus/messages/4 ... 1401312104
410lbs engine & transmission + generator 23bs
https://www.mtfca.com/discus/messages/2 ... 1339332054
https://www.mtfca.com/discus/messages/4 ... 1395839893
