Coil box amperage ?
Modeltmike
Topic author - Posts: 179
- First Name: Mike
- Last Name: Sleep
- * REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 27 touring and 26 Fordson.
Coil box amperage ?
How many amps does a coil box draw. It is my understanding that a single coil should be set at 1.5 amps. Is it as simple as 1.5 x 4 = 6 amps?
Re: Coil box amperage ?
Only one coil is fires at a time, so only 1.5 amps.Modeltmike wrote: ↑Wed Nov 08, 2023 5:27 amHow many amps does a coil box draw. It is my understanding that a single coil should be set at 1.5 amps. Is it as simple as 1.5 x 4 = 6 amps?
- Last Name: Humble
1.3 amps per coil if it is adjusted correctly.
Mark Nunn
- Last Name: Nunn
Instructions for installing an E-Timer say to add a 4 amp fuse to the coil box. Total run amperage needs to be somewhere below that.
Only one coil at a time is in operation, and for some of the time during engine operation, no coil is operating. Average coil current during coil operation is in the 1.2 to 1.5 amp range. A 4 amp fuse would be correct, if a fuse is present. Coils behave differently when operating on battery current (6 volts DC) as opposed to magneto (Alternating current, about 5 volts AC to about 30 volts AC) Two coils will fire during each revolution of the engine.
Been Here Before
- First Name: George John
- Last Name: Drobnock
To add to the discussion, and of course be criticized, if you observe your ampere meter, set the ignition switch to battery, and turn your motor by hand crank, with the coil buzzing, you should observe that the meter will show a discharge of about 2 amps, or one line to the left (a discharge). Of course if you use a buzz box with a three ampere meter, you will note a current draw of 1.5 to 2 amperes.
JohnH
- Last Name: Hunter
- Board Member Since: 2002
The Ford ammeter installed in the dash is far from a precision instrument, and is certainly not accurate enough to set coil current using the buzz box method. It's just a rough guide that everything is working properly.
The 4A fuse specified for the E-Timer is to protect the E-Timer itself, in case a coil is completely short circuited.
