FS Jno brown Brass generator.
BobP
Topic author - Posts: 1024
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 1914 tr, 1916 rdts, 1921 tr, 1923 rdst, 1925 cp. 1927 pu, 1927 tr.
For sale brass jnoBrown carbide generator. good used condition with some dings and imperfections. It is complete except the top part of one clamp that holds the top to the bottom. The lower part of the clamp is there. I am sure if you highly polish it there will be more imperfections that show. Look at the pictures closely. $950. No TEXTING. five07458677eight. Mn.
BobP
Re: FS Jno brown Brass generator.
BTTTTTTTTTTTTT I can do better on the price.
Bill Everett
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
E-Mail sent.
BobP
I was told it could be a Corcoran. I am no authority. Look closely and decide if it is the one you want. I will take $750. Let me know. Call if you are interested, 507 458 6778, Thanks, Bob.
BigAl
- First Name: Alan
- Last Name: Stein
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Your generator is a Corcoran. The only difference between a Corcoran and. Jno Brown is the base. A Jno Brown base is a casting with three mounting holes. If you get the base and the Jno Brown badge for the lower tank you will have a Jno Brown. These are the only differences.
- Last Name: Tannehill
I may be wrong but I believe the clamps that hold the 2 tanks together on a JB are the large wing nuts & swivel post vs the cam & clamp.
BigAl
- First Name: Alan
- Last Name: Stein
I know for 1911 (I have a late 1911) & 1912 the Jno Brown generator has the cam and clamp design along with the casted base and badge otherwise the generators are the same. Some Corcoran and E&J’s have the wing and post as you described. If anyone needs a picture just email me.
BobP
btttttttttttttt
Tbird
- First Name: Mike
- Last Name: Bird
This is my original Corcoran generator
Before restoration and after.
Wow I bet it took a lot to get that straightened, looks like they had it built upside down. Hehehe
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
John, it’s always better to start at the bottom, easier to do that when the bottom is closer to your eyes ain’t it??
