Speedometer installation problem
Allen Banks
First Name: Allen
Last Name: Banks
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster
Post by Allen Banks » Sun Nov 19, 2023 2:27 pm
The mounting bracket isn’t squared up to spindle arm. I don’t think the clamp on the mount is movable. I believe it’s welded in place. I haven’t tried moving it for fear of breaking it. Anyone?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Speedometer installation problem
Post by Dan McEachern » Sun Nov 19, 2023 3:59 pm
The clamp is a separate piece and should be lose on the spindle nut extension, and should be able to rotate. Remove the bolt in the end and tap the clamp until it breaks loose.
Allen Banks
First Name: Allen
Last Name: Banks
Post by Allen Banks » Sun Nov 19, 2023 4:58 pm
That was the issue, just painted on there pretty good. A nice tap in the clamp freed it up.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Nov 19, 2023 5:01 pm
Looks like powder coated glued/melted on. You may need to heat it up to loosen it.
Hank
