Classified ad photos
Larry
Topic author - Posts: 256
- Last Name: Gresh
Does anyone know if the way of attaching pictures to a classified ad has changed? As I have not been able to attach pictures.
Thank You,
Larry
Thank You,
Larry
- Last Name: Tannehill
Re: Classified ad photos
Larry not that I know of but are you seeing the attachments tab or is that not showing up as an option? If it’s not look for the full editor tab and click it. The attachment tab should show up. Best John
Larry
- Last Name: Gresh
John,
I don’t think I’m doing anything different than I used to but I will look at that again when I get home from work.
Thank You,
Larry
Thank You,
Larry
Desktop, phone or tablet? I am on desktop, when I open the start new topic, under the message box I am seeing the options and attachments tabs. Clicking on attachments, opens the window to add photos same as in the past.
Sarikatime
- Last Name: Seress
Make sure if you do not have the green arrow when you want to attach, you go back to your pictures and resize the picture and try to attach it again.
Larry
- Last Name: Gresh
Frank
That actually may be the problem.
I never thought about that.
I’ve switched phones and the photos are probably larger than they were on my last phone.
Thank You,
Larry
Thank You,
Larry
got10carz
- Last Name: Meixner
If you are using your phone like I do, add the AP
( Photo and Picture Resizer). Free version. I resize to 75% and can add 4 photos.
- Last Name: House
Under ad verbiage there’s an ‘Attachments’ tab. Click on it and you’ll see an ‘Add Files’ tab. When I click on it, it’ll give me several locations and I’ll choose ‘Photo Library’. Then click on the picture(s) you want and if they’re of a correct size, there’ll be added. But before I choose ‘Submit’ I’ll go to ‘Preview’. Then ‘Submit’.
Larry
- Last Name: Gresh
Thank you, Mark and George.
I think that’s the way I’m doing it.
I usually hit the preview before posting but when I do the pictures are not there. So I’m guessing they need to be resized.
I will give it a try if I get a break this evening or tomorrow.
Thank you for the help.
Larry
Larry
