Front axle - Tell me what special parts you see
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Post by Matt in California » Sun May 26, 2019 9:13 pm
I was looking at this and noticed a few things. Tell me what you think.
Thanks!
Matt
First Name: Henry
Last Name: Lee
Re: Front axle - Tell me what special parts you see
Post by Henry K. Lee » Sun May 26, 2019 9:21 pm
Matt,
Looks like you found a vintage lift kit with all those added springs. LOL, Must have been a rough ride with a fat girl or something.
All the Best,
Hank
Last Name: House
Post by George House » Sun May 26, 2019 9:23 pm
Well, ... it has LOTSA spring leafs. And it doesn’t have the correct U bolts fastened to the front motor mount. Also it appears that something has been welded to the top of the axle on the bottom left of the front motor mount. But,...with a pint of latex black it could be made to be a Stynoski winner !!
Last Name: Hjortnaes
Post by DHort » Sun May 26, 2019 9:30 pm
Top of left spring perch missing.
Post by Allan » Mon May 27, 2019 4:06 am
The usual spring U bolts would have been discarded as too short to accommodate all the extra spring leaves. Looks like it started out as an erly tper leaf spring, with later shopped end leaves added.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Mon May 27, 2019 4:37 am
Look again Dave, it's there. :) Dave
1925 mostly original coupe.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Mon May 27, 2019 8:25 am
Looks like it may have been made into a trailer at one time.
John Warren
Last Name: Warren
Post by John Warren » Mon May 27, 2019 10:06 am
TT truck set up?
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Mon May 27, 2019 11:08 am
Jim,
You got it! I had a friend contact me and ask if I would get this out of their yard because they were clearing the space for building. It was used as a vineyard wagon. I noticed both front and back had added leaf springs. I added sheet parts to make it into yard art. It also had a draw bar to connect it to the tractor. It was interesting in that it was designed to actually turn the front wheels. I keep that to use when I need to tow my T;) (Yeah I know that would be a bad idea.
The engine mount taken from an earlier because that made it easier than dealing with the the 1926/7 one that was on this frame.
Anyway, I guess I could sell this "lift kit" setup!
Matt
Last Name: House
Post by George House » Mon May 27, 2019 12:14 pm
Well of course it had a second life as a trailer. Farm wagons like that are all over the country. We thought you had something unusual on the “front axle” for which you were soliciting guesses...
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Mon May 27, 2019 1:36 pm
George,
Thanks for pointing out that I am not the sharpest pencil in the pack.
Actually, I thought that the front engine mount was something special. I guess many times it is covered and the fact I have focused on later model Ts (or 1926/7). When I went to post the key to my discovery, in my last post, I finally figured out what key word to search under... Then I found that the punt was really common. My discovery was even simpler than what you mentioned!
This is what I like about the hobby- That you can learn something every day!
Matt
Post by Wayne Sheldon » Mon May 27, 2019 5:03 pm
Many years ago, I had one of those trailer "draw bar" setups in a box full of model T parts that I bought. It was a nice cast iron piece that bolted onto the axle and tie rod to tow and steer the T chassis. I made the missing draw bar and fitted other clamp pieces that were missing. I figured that "in a pinch" it might be handy to tow a T a short distance. Or maybe even a longer distance if the T had a transmission with a real neutral (since many of the Ts I have had were speedsters with such transmissions).
I have never used it. To this day, it leans on the side of a storage shed. Just in case I or someone I know needs one in a hurry.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Tue May 28, 2019 1:28 am
Cool trailer Matt! Nice yard art for sure.
Bah, that's an earlier engine front mount. :)
I think my 18 has one of those but without the flats on the bottom...
I like those wider mounts, they have "a look" to me.
Thank you also for being "that guy" your friends can rely on. To rid themselves of XXXX. Oop, starts with a J.
BTDT. :lol: Loved it all the way.
D Stroud
First Name: David
Last Name: Stroud
Post by D Stroud » Tue May 28, 2019 6:26 am
I have one of those wagon "conversions " drawbar setups for a trailer. I always wanted to build a "T" based trailer to pull behind a "T" based tractor conversion or "Doodle Bug" for parades and shows. Thought it would be cool to haul kids and such. Dave
