Rear Spring Identification
Topic author - Posts: 77
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Is there an easy way to identify whether this spring is 26/7 or earlier. Maybe by the height? If so, what is the height in each case?
- Last Name: Nunn
Re: Rear Spring Identification
Check the Encyclopedia. Go to the "Springs" section for year by year changes.
https://www.mtfca.com/model_t_encyclopedia/s-t/
- Last Name: Young
Could find no info there on how to identify. It doesn't even state there was a difference in shape.
The parts book lists the same spring from '22 to '27. Perhaps the only difference is in the perches.
And the number of leaves.
- Last Name: Nunn
According to the encyclopedia, 8-leaf, non-tapered, rear with the main drilled for oilers was the same from 18-27.
- Last Name: Nunn
The leaf count varied by body style but shape did not. UK cars were lower and might have a different shape.
And even if there was a difference when new, 100 years of rebounding will have made that difference hardly discernible.
Pay attention to what Steve says! The sedans, and pickups use a 9 leaf rear spring.
- Last Name: Young
My apology. I was thrown off by some of the parts catalogs that suggests there was a difference.
