Read main bearing cap thrust Babbitt thickness
Dave1
Topic author - Posts: 94
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
What is the best thickness for the Babbitt on the thrust faces on the rear main cap?
Making a set of bearing caps to accommodate a Chevy crankshaft.
Let’s just say that some of my calculations were wrong, and the cap is a bit undersize in the length direction. Wondering how thick the Babbitt can be finished before it will cause problems?
- Last Name: Tannehill
Re: Read main bearing cap thrust Babbitt thickness
Were you thinking thickness on the interior block side or the transmission side for the Chevy crank, just curious?
- Last Name: Hatch
I think I have set of Chevy main bearing caps I would part with. Email me. Dan
Kerry
- Last Name: van Ekeren
When Ford started with the T and Dodge was suppling, the cap had as much as 1/4" of babbitt on both ends. All the caps had babbitt flanges on them to run flush with the block bearing saddles. In Canadian assembled engines this was done right up into the end of the 16 model, when re-building they show no more than normal wear.
Dave1
- Last Name: Eddie
I have the bearing caps made up. I had planned on having about .050 “ of Babbitt on the rear thrust surface, however it’s looking like about .150”
The final will depend on outcome of the crankshaft grind
Dave1
- Last Name: Eddie
I will be using the rear main as the thrust , rather than the centre main as the Chevy crank was designed
Adam
- First Name: Adam
- Last Name: Doleshal
Thrust is on the front of the cap, so move the cap forward and put about .062” babbitt on the front and the rest on the back. Mill .055” of the iron “face” off the front and rear of the 3rd main saddle and cast & machine thrust in the block too. It will extend the wear life of the thrust almost 3x in theory.
You could also do a little work to the saddle and add thrust to the block.
