WTB
WTB
Post by Original Smith » Mon Dec 18, 2023 9:37 pm
Need one pre 1920 fan blade in perfect condition.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: WTB
Post by Ken Buhler » Mon Dec 18, 2023 11:22 pm
Hello Larry,
I have many fan blades. Show me an example photo and I will see what I have.
Ken
Work honestly
Stay true to your word
Get the job done right
Re: WTB
Post by Original Smith » Tue Dec 19, 2023 11:43 am
Thanks Ken. I will try to get a photo for you today.
Re: WTB
Post by RajoRacer » Tue Dec 19, 2023 12:24 pm
That would be the small steel hub with riveted blades - I might also have some Larry.
Re: WTB
Post by TRDxB2 » Tue Dec 19, 2023 12:32 pm
From the encyclopedia -
1917-1920 (3960)
Similar to earlier type but hub was now cast iron. In 1916 (1917 cars) the fan bracket was changed to the longer and straighter type, which was used until the 1926 models. Early production 1917 cars used a fan shroud behind the radiator but this was apparently discontinued after a short time.
1920-1925 (3961-C)
Beginning May 1, 1920 a larger aluminum hub with one-piece blade assembly (two blade pieces welded together as an assembly) began on trucks at first, then on all cars.
geezert
First Name: Alan
Last Name: McClure
* REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1915 touring
Re: WTB
Post by geezert » Tue Dec 19, 2023 3:42 pm
I have a NICE one looks like new
geezert
First Name: Alan
Last Name: McClure
Re: WTB
Post by geezert » Tue Dec 19, 2023 3:43 pm
3961c if thats what your looking for?
Re: WTB
Post by RajoRacer » Tue Dec 19, 2023 4:18 pm
3960 is what Larry's in search of - I'll look after lunch !
Re: WTB
Post by Original Smith » Tue Dec 19, 2023 4:46 pm
I took two photos, a front and a back. Can't find the front. Let me know if you want me to try again. I'm not good at this stuff!
Re: WTB
Post by Original Smith » Tue Dec 19, 2023 4:47 pm
I hope this will do for now. I can always try again.
Larry Smith
Re: WTB
Post by RajoRacer » Tue Dec 19, 2023 9:13 pm
Are you looking for a brass hub or steel hub Larry ? What year is it going on ?
KimDobbins
First Name: Kim
Last Name: Dobbins
Re: WTB
Post by KimDobbins » Wed Dec 20, 2023 2:15 am
Larry wants a 1913 style blade, brass hub. Not all brass hub fan blades are the same. In 1909-12 the hump in the blade is noticeably larger, these blades are pretty rare. The one Larry is looking for is much more common.
Re: WTB
Post by RajoRacer » Wed Dec 20, 2023 11:30 am
Thanks Kim - I'll take a look but tough to find a brass hub with much crown left ! I installed a new, machined brass hub from Lang's on our '14.
Re: WTB
Post by Original Smith » Wed Dec 20, 2023 12:03 pm
Thanks for all the positive comments. As Kim noted, I need the type used in 1913, and is clearly shown in the above parts list. My fan hub is about the best I've seen. I cotter pin holding the fan bracket on, but somehow vibrated loose, and that's what caused this problem. I think old age has something to do with all this!
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Re: WTB
Post by Craig E. Luton » Wed Dec 20, 2023 3:51 pm
Looks like the flange on the fan hub is cracked.
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Re: WTB
Post by Belliott3 » Wed Dec 20, 2023 5:44 pm
Is this what you’re looking for?
Re: WTB
Post by Original Smith » Thu Dec 21, 2023 4:26 pm
Yes, that's the one I'm looking for! There is nothing wrong with my hub. It's just the blade that broke off. I'd buy that fan you have pictured if you would sell it.
Larry Debaugh
Last Name: Debaugh
* REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout
Re: WTB
Post by Larry Debaugh » Thu Dec 21, 2023 6:29 pm
Larry, I have several complete fans with bad hubs, I’ll send you one, just pay the postage… Larry Debaugh
