For sale: 11 tooth pinion $75 plus postage
pinion 11 tooth
Topic author - Posts: 1714
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
pinion 11 tooth
- First Name: Melba
- Last Name: Nolan
Re: pinion 11 tooth
move to top
Re: pinion 11 tooth
The critical part of a used pinion is the amount of wear on the teeth. If you show the other side of the gear, you may have better luck selling it. The price is right, if the wear is right.
- First Name: Melba
- Last Name: Nolan
Re: pinion 11 tooth
thanks I will do that
- First Name: Melba
- Last Name: Nolan
Re: pinion 11 tooth
those are 2 different pinions. I have a picture of the other side of the bottom one but can't post. can email or text
melbanolan@aol.com or 314+575-7115 price same for either plus postage
- Last Name: C
Re: pinion 11 tooth
Posting Additional Pictures of Teeth for Mr. Noland.
- Last Name: C
Re: pinion 11 tooth
Additional Pictures of the G2 marked with Ford script
