Need help
Ron Patterson
Need help
Post by Ron Patterson » Mon Dec 25, 2023 4:34 pm
Anyone have ideas how to tighten the encircled nut.
It is 5/8 across the flats and a normal
5/8 end wrench is very ackward.
Ron Patterson
Kerry
Last Name: van Ekeren
Re: Need help
Post by Kerry » Mon Dec 25, 2023 4:39 pm
If you have a spare ring spanner then cut a piece out the width of the pipe.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Need help
Post by Erik Johnson » Mon Dec 25, 2023 5:04 pm
James Yuill
Last Name: Yuill
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Board Member Since: 2023
Re: Need help
Post by James Yuill » Mon Dec 25, 2023 5:38 pm
Very awkward..no room. I put a new shut off valve to the carb and used an open end wrench and had to attack it on an angle with the top of the wrench angled toward firewall. It's a slow process but worked for me.
JYuill
Last Name: House
Re: Need help
Post by George House » Mon Dec 25, 2023 5:48 pm
Sacrifice a 5/8” open end wrench to the bench grinder god… thats 3/4” to the left and 5/8” on the right. It’ll quickly do the job.
Ron Patterson
Re: Need help
Post by Ron Patterson » Mon Dec 25, 2023 6:13 pm
Thanks Dan
knew what it was but couldnt come up with the correct name.
Ron Patterson
Last Name: Patrick
Re: Need help
Post by jiminbartow » Mon Dec 25, 2023 6:34 pm
The 4th wrench down, the “tubing or line wrench” is what you need. It is basically a 6 sided box end wrench that has a slot cut out of it to allow it to fit over the tube then slides onto the nut.
You can make one of these by using a Dremel tool with a metal cutting disc to cut a piece out of a thin walled, 12 sided box end wrench, wide enough to allow it to clear the tube, then you can slide it onto the hex fitting. With a slotted box end wrench you have 12 sides instead of 6 so you don’t have to turn it so much during repositioning. Turn it, slide it off, reposition, slide it back on, turn it, etc. Jim Patrick
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Re: Need help
Post by South Park Zephyr » Tue Dec 26, 2023 10:39 am
I have had a set of these wrenches for years.
A google search of “offset head open end wrench” will get you to several sellers
Last Name: Patrick
Re: Need help
Post by jiminbartow » Tue Dec 26, 2023 12:10 pm
I don’t believe an open end wrench will work because the sides are too fat to fit in the space on each side of the hex fitting, unless the sides of the wrench are ground down thin enough to fit into the spaces. Jim Patrick
Harvey Bergstrom
First Name: Harvey
Last Name: Bergstrom
Re: Need help
Post by Harvey Bergstrom » Tue Dec 26, 2023 12:18 pm
All you should need to do is take off the hood shelf on that side and you should have plenty of room to disconnect the gas line.
Last Name: Wrenn
Re: Need help
Post by TWrenn » Tue Dec 26, 2023 12:36 pm
That just adds way too much work to it.
This ain't rocket science. Like Jim said...get that offset open end wrenches and cut the sides down thinner so they fit in. I've been using a small crescent wrench for years with no issue. The hardest part is just getting the stupid nut to line up square enough to the threads to get started. No matter what you use, you're just gonna have to be patient enough as you'll only get very short turns each time. It'll get there!
Re: Need help
Post by RajoRacer » Tue Dec 26, 2023 1:18 pm
Do yourself a favor Ron & purchase a set of flare nut wrenches - inexpensive and you'll find other uses for them !
Last Name: House
Re: Need help
Post by George House » Tue Dec 26, 2023 2:07 pm
Jim, the second half of your sentence is exactly what I was suggesting and pictured. Heck, you don’t need “12 sides” to tighten or loosen that fuel line nut. 😂
Susanne
First Name: Susanne
Last Name: Rohner
Re: Need help
Post by Susanne » Tue Dec 26, 2023 2:43 pm
Crowsfoot socket will work as well... Connected to a T handle slid all the way to one end, it makes a decent job of it.
Re: Need help
Post by DanTreace » Tue Dec 26, 2023 4:38 pm
Why buy a modern wrench?
Your Ford tool kit came with the proper tool, works fine.
The 1917 Band Nut and Pack Nut Wrench. The ends of the jaws of this wrench are factory formed splayed or slightly apart, so applying the wrench also at an angle will allow the wrench jaws to easily pull up that pack nut! ;). That is also why the trans band end works too, as you approach the band nut also at an angle.
Re: Need help
Post by Allan » Tue Dec 26, 2023 6:17 pm
See Kerry's first response. Subsequent posts suggest the same thing, but I suspect they didn't recognise what a ring spanner is. How you guys get a box wrench out of a circle is beyond comprehension. Does it hark back to the horse and cart days when axle nous were square, like a box? ;)
Dan, I must check out using T1917. Makes perfect sense.
Allan from down under
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: Need help
Post by Dennis_Brown » Wed Dec 27, 2023 12:11 pm
I saw a ratchet and socket set years ago that I wish I had. It was one that the sockets slipped into the ratchet and were of a tubing wrench design. You lined up the opening and slipped it over a tube and could tighten down the flare nut. Slid it backwards and lined up the slot and took the wrench off. It was not big and bulky and more the sise of a 3/8 ratchet handle.
vping
First Name: Vincent
Last Name: Pina
Re: Need help
Post by vping » Mon Jan 01, 2024 8:52 pm
Was dealing with this today. Don't seem to have that wrench in my collection, so a small metric adjustable and little turns did the trick.
