Parts identification
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sat Dec 30, 2023 8:05 pm
My '25 came with a few boxes of parts. Some I know and some I don't do I'm hoping the forum can help.
This is a random switch.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Parts identification
Post by Dan McEachern » Sat Dec 30, 2023 8:40 pm
Possibly a post '15 headlight switch- used up to ? on non-starter cars.
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sat Dec 30, 2023 9:12 pm
Interesting. I'm still trying to locate my headlight switch on the dash.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sat Dec 30, 2023 9:45 pm
1915 through early 1918 model year headlight switch.
A few months in to the 1918 model year, Ford went with the combination horn/light switch on the steering column.
Post by TRDxB2 » Sun Dec 31, 2023 12:12 am
Its a dash mounted push/pull headlight switch. To be precise its a later model defined by the length of the cylindrical portion.
The first versions were brass, next was a long cylinder body, then shorter with protruding contacts. The repros are similar to the shorter style.
Good find $$. Note: The originals were a simple design to complete the positive wire connection. They need to mounted on a wood dash since they were not well insulated internally.
all mounted in the same position
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sun Dec 31, 2023 11:10 am
I've yet to find the headlight switch on my car so I guess this isn't right for a '25TS.
Post by RajoRacer » Sun Dec 31, 2023 11:25 am
The headlight switch for a '25 is the lever on the key switch.
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sun Dec 31, 2023 7:49 pm
Thanks. Yeah just discovered that. So much to learn and find out about the T I keep bouncing all over the place.
