Shrinner Model T help
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Sun Dec 31, 2023 5:27 pm
Just picked up an old Shriners Model T car. It doesn't have an engine. I know nothing about them other than what they are. I'm looking for any information on them. I'd like to get it back up and running if possible. Any photos, what engine it took and so on. Thank you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
havnfun
First Name: Joe
Last Name: Kowalczyk
Re: Shrinner Model T help
Post by havnfun » Sun Dec 31, 2023 6:11 pm
They originally took a 3 or 3 1/2 hp Briggs and Stratton engine, I’m actually a Shriner and was a member of the Tin Lizzie’s. I have an original good running engine, I live in Idaho.
Hopefully you can find an engine closer.
Send me an email, I’ll email you pictures and send you phone #
Regards,
Last Name: Hatch
Post by Dan Hatch » Sun Dec 31, 2023 6:19 pm
Will: Most of the ones like that were made by McDonough Equipment Co. In McDonough Ga. Same people that made Snapper mower.
Look for a tag that says that. Dan
Check out this link
http://tradenationllc.com/product/origi ... in-lizzie/
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Sun Dec 31, 2023 6:31 pm
The motors are commonly replaced with Harbor Freight Predator Motors.
Post by TRDxB2 » Sun Dec 31, 2023 6:41 pm
Possible source of parts & they may be able to answer your questions https://gokartguru.com/model-t-go-kart-parts-store/
More info from them https://gokartguru.com/tin-lizzie-go-kart/
Model T GoKart Engines
The motor types typically were 3.5 Hp Briggs and Stratton, or 3.5 Hp Techumseh. The vertical engined versions typically were 3.5 hp Briggs and Stratton.
The throttle for the motor was actuated very similarly to the original Model-T, in order to be more period correct or true to the original design. The throttle was actuated under the steering wheel stalk with a lever that is pull down or up depending on the speed setting. There is a second dumby lever that does nothing. The throttle cable is a steel sheathed solid steel cable that is around 48 inches long. There is no on-off switch, especially for the Tecumseh version, a spark shorted to the plug is pressed against the plug to make it stop.
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Sun Dec 31, 2023 8:07 pm
The wheels and tires can be an issue. On ours, the tires were no good, and the previous owner had attempted to use bicycle tires and tubes. This was not successful, as the wheels had no lip for the bead of the tire to grab. I was able to buy a couple of cheap bicycles from Walmart, and turn the plastic T wheels on a brake lathe. I cut off the inside edge of the wheel, and tuned down the wheel so that the steel rim from the bicycles was a press fit over the wheel, and against the outside rim. Then I drilled through some of the spoke holes in the bike wheels and ran deck screws through the steel rim into the spokes of the plastic wheels. Now I use standard bicycle tires and tubes.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Last Name: Patrick
Post by jiminbartow » Mon Jan 01, 2024 10:43 am
Here are a few pictures of my Model T Go cart. While our family was driving through Bainbridge, Georgia on vacation in the early 1964, my Dad happened to see it at a filling station as he was driving over an over pass. He took the off ramp for a better look and wound up buying it for $50.00. We drove home, 316 miles to Brandon, Florida with it tied down to the roof of our 1957 Ford Fairlane. At 12 years of age, I got it running and restored it to the best of my minimal experience and it provided me and the neighborhood kids with many years of fun. The last time I drove it was in 1970 when I bought my 1926 Model T coupe and began spending all my time and money restoring that. I turned 70 in November and plan to, one day, restore the go cart to mint condition if I am able to live that long. I hope the pictures help. The Briggs and Stratton engine and running gear are original and can be easily restored to running condition. Jim Patrick
Last Name: Hatch
Post by Dan Hatch » Mon Jan 01, 2024 12:37 pm
Since these were made by same people that made Snapper I have wondered if the power train was not something used on Snapper mower? Anyone know?
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Jan 01, 2024 4:31 pm
I don't recall the company name, but I still have their catalog.
Rumor had it the 16 inch plastic wheels exploding caused the company to shut down.
The small volume of air required to fill the tire tube and too much air pressure caused a disaster.
They did come out with aluminum wheels later on.
A friend recently still had this one for sale.
Mini T Engine.jpg (56.68 KiB) Viewed 2642 times
BubbaSmithTinLizzy
First Name: Tony
Last Name: Albers
* REQUIRED* Type and Year of Model Ts owned: 1910 Torpedo
Post by BubbaSmithTinLizzy » Mon Jan 22, 2024 11:35 pm
Hi Will,
You just purchased a 1959~1965 McDonough Tin Lizzy. If you look on the back frame of your car (left side) and you will see an aluminum nametag with stamped 6-digit code. That code will help tell you the exact year it was manufactured.
The original engine that came on early cars like yours was a horizontal shaft, 3hp, Briggs & Stratton "81302". Also, there is a active Facebook group with people that collect and restore these half-scale Model T's. That group can help you find any missing parts needed. On Facebook search for a group called "McDonough Power Equipment Tin Lizzy and Buckboards". These little cars are a great way to get kids interested in full size Model T's.
Last edited by BubbaSmithTinLizzy on Tue Jan 23, 2024 3:33 pm, edited 5 times in total.
BubbaSmithTinLizzy
First Name: Tony
Last Name: Albers
Post by BubbaSmithTinLizzy » Mon Jan 22, 2024 11:44 pm
Hi Dan, yes both McDonough Power Equipment (1959~1965) and later Crue-Cut Manufacturing (1966~1979) used that same style transmission for there half-scale Model T's. That tranny came from the Snapping Turtle lawn mower. Attached is a 1956 advertisement showing its original application.
BubbaSmithTinLizzy
First Name: Tony
Last Name: Albers
Post by BubbaSmithTinLizzy » Tue Jan 23, 2024 3:41 pm
Will, as requested here's a photo of the what the original engine on your car would have looked like (3hp Briggs 81302). Notice, Tin Lizzie's built before 1963 used round Oil Bath Filters. Tin Lizzie's built after 1963 with 3hp Briggs engines used kidney shaped foam air filters.
