'27 floorboard question
Brent
First Name: Brent
Last Name: Coil
* REQUIRED* Type and Year of Model Ts owned: 1914 1917 1926 1927
Post by Brent » Thu Jan 04, 2024 11:52 am
I am working on my '27 Tudor. On the floorboard support angling up at the front, my car has a brass colored rivet on the metal support on each side. Any Idea what this would have been used for?
https://www.mtfca.com/phpBB3/download/f ... &id=180031
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: '27 floorboard question
Post by Humblej » Thu Jan 04, 2024 12:04 pm
Those hold the carpet.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Jan 04, 2024 12:10 pm
My '26 Runabout does not have rivets there or holes for them.
Brent
First Name: Brent
Last Name: Coil
Post by Brent » Thu Jan 04, 2024 12:49 pm
thanks so much
Post by RajoRacer » Thu Jan 04, 2024 12:51 pm
Open cars didn't have carpet.
Post by DanTreace » Thu Jan 04, 2024 12:52 pm
Only thing on the rivet is if 'colored' like brass, may have been brazed at the factory, lots of brazing was done to secure things.
Check it with a magnet to test for steel.
Only enclosed cars got carpet as standard. Front carpet has snap fasteners to keep it down. The tabs on the side of the riser hold the kick panel in place, the rectangular pivoting plate holds down the floorboards.
But you could get rubber mat for closed cars for a while!
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Jan 04, 2024 1:12 pm
After installing all the floorboards use a screwdriver or pliers to turn that riveted piece of short metal horizontal. That was put in to hold the floorboards in place, helpful on washboard roads.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Thu Jan 04, 2024 1:54 pm
Could that be the female half of a snap, installed by a past owner? The male half would have been installed on the floor covering and snapped down onto the female half to prevent the floor covering from blowing out. My 1926 coupe has snaps for holding the carpet in place. Jim Patrick
Upper photo is the male half. Lower photo is the female half.
jab35
Last Name: Bartsch
Post by jab35 » Thu Jan 04, 2024 8:53 pm
My unrestored '26 coupe has those identical factory installed features, and of course, would have had the carpet too, thanks for bringing this information to the forum. jb
