Kellogg Engine Air Pump
Topic author - Posts: 589
- First Name: Tad
- Last Name: Glahn
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
I picked up the attached Model 101 Kellogg air pump and didn’t know if anyone else had a similar model mounted on an engine or photos of one mounted to operate. This one seems complete other than a way to drive power to it, the hand clutch works good and the shaft seems to have a key way in it. I have been having a hard time finding literature on this model/style of pump.
- First Name: craig
- Last Name: leach
Re: Kellogg Engine Air Pump
Hi Tad,
I hope you find some info on that air pump. I picked up one years ago that appears to have had some kind of clutch or means of engagement
but looks to have been driven from a engine directly. It's a two stroke style. I found it at a church rummage sale. All it has on it is B&S and a
illegible model or serial number. I have not looked for info in years because I found nothing before. Craig.
From this ad "a very old Kellogg's tire pump...some were mounted on the cars themselves, others were used at old gas stations for pumping up car and bicycle tires....this model #101 was made in rochester, ny ...pat. is 1916/1918.
https://www.worthpoint.com/worthopedia/ ... 1924508126
FWIW
FWIW
