What is the best and strongest way to secure a fitting to both ends of a length of stainless steel braided hose that will be used for water and/or oil. Can you recommend the necessary parts (ferrules or clamps) and tools to accomplish this? Please be as economical as possible. Thank you. Jim Patrick
Making strong flexible braided hoses
Topic author - Posts: 2457
- Last Name: Patrick
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Re: Making strong flexible braided hoses
Jim, This method is the way I have made hoses for many many, years. Good Luck.
https://www.youtube.com/watch?v=PeeflgGlenY
You will have to find the fittings to fit your needs. Generally, you have a "collar" that goes on the hose end, then the fitting that threads into the collar with a tapered end inside the hose. I have seen radiator hose collars that just hide the hose end with a hose clamp inside the collar to tighten on the hose as you would normally have.
- First Name: Austin
- Last Name: Farmer
Where i work (Aircraft maintenance) we use a.e.r.o. hose shop and like their work. Im new to the Aircraft maintenance industry, and i dont know if they do car hoses, or just aircraft stuff, but we just got a shipment of stainless steel braided hoses from them yesterday, what a coincidence...
***Now i dont know if the fittings would be the same, and if they are even compatible.***
Just my 2 cents worth
https://www.aerohoseshop.com/
Are these for use on a T Jim?
John.Zibell
- Last Name: Zibell
Any hydrolic shop can secure the fittings for you. Do a web search, or ask a farmer for one in your area.
1926 Tudor
- First Name: craig
- Last Name: leach
Hi James,
The recomendations are great for high pressure requirements. If for low pressure as in model T apllications try Speedway Motors they have a
good selection of clamps for all aplications.
