Conversation Pieces - T Frames
Topic author - Posts: 64
- First Name: Lyndon
- Last Name: Moore
- * REQUIRED* Type and Year of Model Ts owned: 8
Found, in a wooded area, not too far apart. Had to cut down several bushes and a few trees to get them out. As you can see part of a tree grown into the trailer hitch. Decided to stack one on top of the homemade wagon just to haul them home. A lot of mixed models of parts. The engine # shows to be a 1925. The wagon shows to be a 26 or 27 model. But the front axle is earlier. There showed to have been a grain bed on the wagon at one time. And probably some kind of seed cleaner or dryer mounted on it, because of the blower on it. My main question on the frame on top, is about the logo stamped on the rear cross member. Not sure what this stands for. And no, I am not going to fix either. Just a lot of good parts. There is a good set of wire wheel hubs, and the wheels were converted to 16's.
- First Name: Keith
- Last Name: Daniels
- * REQUIRED* Type and Year of Model Ts owned: 1927 TT Truck, 1926 Touring
Re: Conversation Pieces - T Frames
What are your thoughts on the chain drive?
- Last Name: Moore
The shaft is attached to the gear box that was powered by the PTO in front of the trailer. Then the chain attaches to a large blower. That is why I think it is some kind of seed cleaner or dryer. It also had a shoot on it. All the hardware was still there for the bed. But all the wood had rotted away.
- First Name: Keith
That would explain the U joint at the front, that had me scratching my head too.
- First Name: Mack
- Last Name: Cole
Well that top 1 is speedster bones!
Glad they were saved!
Looks like a Person of Largeness sat on the gas tank....
- First Name: Mack
- Last Name: Cole
Had to be bigger than me then because mine didn't cave in when i sat on it!
That’s a good find. Model T bones are still out there. When they were used up they were pushed off in the woods or out in the back fourty and just forgotten about. If the frames are not mangled they probably are good for parts at least. More than a few T’s have been built up from remains like these.
If the spark plugs are still in the engine it may be a good usable block.
One man’s trash is another man’s treasure as far as old car parts are concerned.
- First Name: Bryant
- Last Name: Shafer
Nice treasures!
Bryant
- Last Name: Moore
I would say, the reason it is so clear to see. It said to not have had a body on it for over 50 years. Which makes it not hold moisture, preventing some of the rust. I would really like to know the meaning. I cannot believe someone out here doesn't know.
I remember when google used to try to answer questions. But I got nowhere trying to find the answer I cannot quite remember.
I have seen that logo before, and it has been discussed here in the past, so someone smarter than I should know it.
Somehow, I think the "P" stands for "Parrish" or something similar. I know it was one of the automotive frame manufacturing companies Ford used for many years to provide frames when their inhouse manufacturing ran short on the factory demands and sales.
Although many people think of the model T Ford as a totally inhouse built automobile, it really never was. Throughout the brass era cars, most of the major and minor components were made by outside suppliers (or in the earlier years Ford's own Ford Manufacturing Company). Once the assembly line got really going, Ford began expanding their inhouse manufacturing of major components. But they never made anywhere near all the parts themselves. Production scheduling ebbed and flowed, and shortages of capacity happened often. Around Detroit were many smaller manufacturing specialists ready willing and able to fill their need. That frame is one such frame.
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
Trying not to hijack the thread. My wife and I found this in the woods a few years ago while hiking. Any clue to what it is? Sorry if I posted this already.
https://photos.app.goo.gl/HQtgZhJG2An4grJP6
- Last Name: Shafer
So it’s possibly a P? Looks like a B. Maybe a P and R overlap since the bottom is not connected ParRish m Co ? Wow what funWayne Sheldon wrote: ↑Sat Feb 03, 2024 2:52 am
Bryant
- Last Name: Shafer
Looks like a small drum era T frame to me. No engine/trans/front axle. Radius rods rigged up to keep it centered with no torque tube. Maybe used as a log skid behind a single mule or something until a wheel busted and was left for dead.vping wrote: ↑Sat Feb 03, 2024 8:33 amTrying not to hijack the thread. My wife and I found this in the woods a few years ago while hiking. Any clue to what it is? Sorry if I posted this already.
Bryant
- First Name: Mack
- Last Name: Cole
I have a chassis with PB on it and I remember Parrish being said for sure,and I want to say,the B was for "Bareington?" spelling.Wayne Sheldon wrote: ↑Sat Feb 03, 2024 2:52 amI remember when google used to try to answer questions. But I got nowhere trying to find the answer I cannot quite remember.
I believe it was Parrish & Bingham.
- Last Name: Shafer
Bryant
