Axle gear
JBog
Topic author - Posts: 295
- First Name: Jason
- Last Name: Bogstie
Axle gear
Are there any vendors that sell new axle gears? I see new axles at the vendors, but not the gears that attach to them.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Axle gear
No need- there are plenty of good original gears out there. A good majority of trashed or worn axles have good gears on them.
- Last Name: Hatch
Re: Axle gear
There even some NOS gears if you know where to look.
jab35
- Last Name: Bartsch
Re: Axle gear
Jason: Lang's has helped me with items like this. They have many parts that are not listed in the catalog. Best, jb
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Axle gear
The new axle shafts are 1.063”. Originals are 1.062”. The original gears can have variations in their inside diameter. Some are worn oversize and some are undersize enough to be too tight of a press fit on a new axle shaft. To do a good job of fitting a good used gear to a new axle shaft, you really have to measure the gear inside diameters all over with a dial bore gauge & pick a gear that has a good .0015” to .0020” press fit. You also need to have a good quality press that is large enough to press a gear off and on.
