Waukesha Ricardo Head differences
Jack Putnam, in Ohio
Topic author - Posts: 486
- First Name: Jack
- Last Name: Putnam
Recently I was able to compare heads made by Waukeshe engine company. If you look closely you can identify several differences in these two heads. I do not know which one is the earlier of the two.
Last edited by Jack Putnam, in Ohio on Thu Feb 08, 2024 2:02 pm, edited 1 time in total.
- Last Name: Hatch
Re: Waukesha Ricardo Head differences
Just a swag but the one with priming holes is early?
I have no proof, but I would think that the priming holes would be removed in later production. Dan
I have one of each Jack & always was under the impression the primer cup model was earlier.
ModelTWoods
- First Name: Terry
- Last Name: Woods
I've owned two and both were the early type with priming cup provisions.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
There was actually 3 versions. Here is an early one. It had a different plain combustion chamber.
