I would like to hear from members who have purchased and installed the 5099-12v Model T WOSP stater.
How does it perform and if the standard bendix assembly fits.
George
Nunsio1
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Re: 5099-12v Model T WOSP stater
I purchased a WOSP starter for my 24 T, from Snyder’s T parts. Installation was easy, works great with no problems with bendix. Only a slight problem with an oil leak ,see my correction in past posts , by looking up WOSP oil correction. I worked with Snyder’s on fixing the issue and I think the company has resolved the problem since then. I would recommend this starter to anyone thinking of moving in that direction.
John M
Oscoda, Michigan
John M
Oscoda, Michigan
Kerry
- Last Name: van Ekeren
They have a Bendix that works on the other side of the T ring gear like a modern car, the one I fitted works great.
Nunsio1
Sorry for the typos, search WOSP starter oil leak correction in the forum.
John M
John M
Unprr
Topic author - Posts: 291
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
John, found your oil leak correction.
Thanks for the advice and I just ordered my WOSP starter.
George
George
