Chickasha Swapmeet
Ed Donnelly
Topic author - Posts: 11
- First Name: Ed
- Last Name: Donnelly
- * REQUIRED* Type and Year of Model Ts owned: 25tt, 26roadster, 26coupe, 24touring, 26roadster pu
- Board Member Since: 2013
Chickasha Swapmeet
What are you bringing to Chickasha Swapmeet
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Re: Chickasha Swapmeet
Ed:
we are not seeing nearly as many Chickasha posts as we did years ago ... i will be bringing my usual babbitt bearing tools , the mainbearing linebore units for models A and T Ford mainbearings , main and rod bearing molds , re-babbitted model T ballcaps , several aftermarket model t distributors ,miscellaneous carburetors , several magnetos ... i am looking for Dodge Brothers 20" disc wheels and period correct Masonic automotive items ...see you all there ... i am in the south building at SL4-SL6 next to the Tannahill/Temple site ...Gene French
- Last Name: Tannehill
If I can make it I’m bringing some early items such as side lamps, Brown 60’s, 85’s headlamps JB Model 15, early E&J Patent Pending sidelights Large style for 09/10. Regular Style with Flare Patent pending. E&J HEADLAMPS (New reproduction in Box).
Double twist Rubes & Nonpareil for Ford, 2 Sears motor buggy horns and some other pre 15 stuff. Also a real 1911 Torpedo steering column with correct frame mount. Best John
Tracer
- First Name: Andrew
- Last Name: Webb
- * REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
I will be there with cash
Gene_French
- First Name: Gene
- Last Name: French
have added several more "single "re-babbitted connecting rods to my pile of items i am bringing to the meet ( i have 1 set of -.010 re-babbitted rods with X oil grooves ) ... i will have my linebore and babbitt molds as usual ...and i am scheduled to pickup 2 motor blocks and crankshafts for customers for re-babbitting the mainbearings ... this will save freight 1 way ... see you all there , have a safe trip ...Gene French
- First Name: Keith
- Last Name: Townsend
I'll be there and will bring some pictures of dead presidents. I can't think of anything that I need, but will know it when I see it.
Keith
Keith
- Last Name: House
So… Keith…. you’re not bringing any 100s ??
He could be bringing McKinley’s, Cleveland’s, Madison’s but not Chase’s. I believe bringing a Wilson would be way over the top & just showing off.
I believe Hamilton & Chase are the only Sec. of Treasury on bills & Franklin was an inventor & First Postmaster General
Gene_French
- First Name: Gene
- Last Name: French
Brassworks low radiator i had listed is sold ... will be picked up at Chickasha ... thanks MTFCA ...Gene French
Ed Donnelly
- First Name: Ed
Bringing rebuilt Ruckstell rearend w/added right side, new drive shaft plus, stableizers, u joint assembled. I'll be in south building.
Gene_French
- First Name: Gene
- Last Name: French
Brassworks ( low ) radiator MAY NOT be sold ... will be at my spaces SL4 - SL6 in south building ... first $750 get it ... this may have been used to test run an engine since it has been used ... is in excellent condition and was stored in the original box with the shipping foam inplace ... this is the round tube radiator ... currently on the plus side of $1000 ... Gene French
23ford
- First Name: Warren
- Last Name: Webb
I was going to try to attend trailer loaded but health says otherwise. If you7 come thru Tulsa call me and go thru trailer. nine one 8 six nine three five 26 seven good hun
ting
dobro1956
- First Name: Donnie
- Last Name: Brown
I will have a bunch of general T items. Some NOS small chassis parts. Some KR Wilson and couple Stevens tools. Several Ford z-tools and pullers. A pair of Laurel style underslinging brackets and a pair of RAJO style offset spindles. Plus other stuff.
Modeltmike
- First Name: Mike
- Last Name: Sleep
- * REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 27 touring and 26 Fordson.
A unique automotive item. A jump seat. 1912. It was used in a Rolls, but was sold for any car of the day.
