Timing
Re: Timing
If you do advance the timing, do it after the engine starts. Otherwise you might not be able to use the crank until your arm completely heals!
Re: Timing
You must like your food Smoking hot!
RVA23T
- Last Name: C
Re: Timing
Thats how my mother remembers the rolls are in the oven, at family gatherings!!
- Last Name: Hjortnaes
Re: Timing
I think it is more common to put chocolate inside your rolls.
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Timing
Is that a Rolls Canardly?
Les Schubert
- First Name: Les
Re: Timing
You know; rolls down one side can hardly make it up the other side!
