WTB Front Fender Brackets
J1MGOLDEN
Topic author - Posts: 1291
- Last Name: Golden
A friend that does not do Email needs a pair of Ford T front fender brackets and asked me to help him find them. They are:
A Part Number 4852 for the Ford 1915 - 1925 Front Fender Iron Bracket Left Side
A Part Number 4853 for the Ford 1915 - 1925 Front Fender Iron Bracket Right Side
Jim Golden, Bowie, MD
Re: WTB Front Fender Brackets
I have quite a few pair - '15 - '16 irons are a bit different at the headlamp post mount - they're "one-sided" as are the correct headlamp. Shipping them might be a bit of a problem - kinda long.
J1MGOLDEN
- Last Name: Golden
Steve, those parts that attach to the frame are just called irons in my 1928 Ford parts book.
The part I need has two rivets on each side to attach to the fender with them, and they are called brackets.
They will fit in a box about 6 X 6 X 4 inches.
Most dealers have the rivets, but not the part.
- Last Name: House
Jim,
Are these the brackets you need ? They’re pretty solid.
$20+ mailing….george
- Last Name: House
….and the round gas tank with mounting brackets will be listed next week
- Last Name: House
Here’s a 3rd fender bracket for your selection
My mistake - I had fender irons in my head !
George looks to have two front brackets for the same side, and a rear bracket.
J1MGOLDEN
- Last Name: Golden
Allen, you are correct, they are all right side brackets for some reason.
Actually, my friend needs the left side the most, if he can only get one.
J1MGOLDEN
- Last Name: Golden
George, he found the right side and now only needs the left side.
This is the one he has now.
Congratulations folks. When you talk left and right, there is no confusion.
- Last Name: House
Well, if he can’t find a loose DRIV…er, ah; I mean left side bracket; contact me. I have a junk, non restorable left fender and a hand grinder
J1MGOLDEN
- Last Name: Golden
George:
I sent your note to my friend.
- Last Name: House
Got it James. I’m going to another property after church today and will pick up the errant left fender for surgery…
J1MGOLDEN
- Last Name: Golden
George, Don is anxiously awaiting your call, I could not give him your number.
