wood coil box stain and seal
ernieh247
First Name: Ernie
Last Name: Hahne
* REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Post by ernieh247 » Fri Mar 15, 2024 2:21 pm
I just purchased a complete rebuild kit for my coil box. The wood is hardwood but doesn't appear to have any stain or sealant. I have read several items on the forum about what should be used. Any new recommendations? I have some stain and polyurethane in my wood shop. Would that be suitable?
Thanks,
Ernie
Re: wood coil box stain and seal
Post by DanTreace » Fri Mar 15, 2024 6:17 pm
Have used clear polyurethane thinned a bit to soak in on the solid oak coil box wood parts. Works fine, sealing that wood from moisture is a good idea.
ernieh247
First Name: Ernie
Last Name: Hahne
Post by ernieh247 » Fri Mar 15, 2024 6:24 pm
Thank You!
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Mar 15, 2024 6:56 pm
Multiple coatings of boiled linseed oil is another method to seal wood from moisture.
Post by Allan » Mon Mar 18, 2024 2:50 am
Beware of linseed oil. In hot weather there is a chance excess oil will bleed out, and this makes getting the coils out of the box extremely difficult.
Fire_chief
First Name: Charlie
Last Name: Gagel
Post by Fire_chief » Mon Mar 18, 2024 5:22 am
Going along with Allan's warning about linseed oil, oil soaked rags have to be disposed of carefully. These rags will self combust spontaneously if not disposed of properly. I would use spar urethane to coat the wood.
ernieh247
First Name: Ernie
Last Name: Hahne
Post by ernieh247 » Tue Mar 19, 2024 8:19 am
Good information, Thank You!
Moxie26
Post by Moxie26 » Tue Mar 19, 2024 12:11 pm
With Alan's post, .......
, since my coil box is on top of the engine I have not had problems with sticking boiled linseed oil coated wood coils , in a boiled linseed oil coated wood coil box , hot or cold weather . Proper disposal of application material is always important.
