Pending F/S Hastings Taper Gage NEW even Lower price $35+ride
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Mar 15, 2024 10:46 pm
Period Hastings Taper Gage in box ( box not super great) Absolute Guarantee will replace or repair without charge at any time gage fails to
function is printed on the box. was $100 now $80 Now $65+ the ride. Now $50 + the ride One more try $35 + shipping six0two-7six9-0two57
First Name: craig
Last Name: leach
Re: F/S Hastings Taper Gage Lower price
Post by Craig Leach » Thu Mar 21, 2024 11:58 pm
post again
WorldChamp1914
First Name: Gary
Last Name: Hagen
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Post by WorldChamp1914 » Fri Mar 22, 2024 2:27 am
What does it measure?
Last Name: Tannehill
Post by JTT3 » Fri Mar 22, 2024 8:01 am
Taper in cylinder
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Mar 22, 2024 5:02 pm
John is correct it measures cylinder tapper ( not bore size ) Made by >-Hastings->piston ring Co. Although the instructions tell how to use it with
a outside micrometer for bore size. A period tool that does the same as the Starrett 452-B that I have used for decades. But Starrett 452-B's now
sell used for $250 & new for over $700.
Craig
First Name: craig
Last Name: leach
Re: F/S Hastings Taper Gage NEW Lower price
Post by Craig Leach » Mon Apr 01, 2024 1:01 pm
Back to the top
ModelTGal
First Name: Jennifer
Last Name: Pierce
Post by ModelTGal » Mon Apr 01, 2024 1:06 pm
Pardon my ignorance, but why/how would there be a taper in the cylinders???
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Apr 01, 2024 3:44 pm
Hi Jennifer,
There is more combustion pressure & less oil at the top of the cylinder so the rings tend to cause more wear @ the top.
The rings don't travel all the way down the cylinder so there is also less wear @ the bottom Of the cylinder. Excessive
taper will cause the rings to flex & break or not make good contact with the cylinder leading to compression loss.
Rotational force can cause the cylinder to wear out of round which can be detected with the same gage. It is almost impossible
to detect a few thousands of an inch with the naked eye & if you could you would need to measure it accurately.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Apr 22, 2024 11:10 am
Still for sale
First Name: craig
Last Name: leach
Re: F/S Hastings Taper Gage NEW even Lower price
Post by Craig Leach » Wed Feb 05, 2025 8:02 pm
Even lower price
First Name: craig
Last Name: leach
Re: F/S Hastings Taper Gage NEW even Lower price $35+ride
Post by Craig Leach » Tue Nov 04, 2025 11:54 am
Much lower price
