Border patrol
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Border patrol
Post by Rich P. Bingham » Mon Mar 25, 2024 7:45 pm
Caption states “1930’s”.
s
Get a horse !
Re: Border patrol
Post by John kuehn » Mon Mar 25, 2024 7:54 pm
Are the wire wheels early V8? If they are I wonder how they mounted them.
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Border patrol
Post by ModelTWoods » Mon Mar 25, 2024 8:43 pm
Wire wheels are Early Ford V8 (probably 16" from 1935). How they mounted them is unknown, but people were resourceful, even back then.
Re: Border patrol
Post by Allan » Tue Mar 26, 2024 12:29 am
There is a couple of A models here with 36 V8 wheels. Makes them look like hotrod! Apparently they are a bolt on fit, so T to A adaptors would work.
I put 16" Chev wheels on a T once. While the tyres gave good flotation on loose sand, the car was almost impossible to steer, having way to much kickback through the T front end.
Perhaps the border patrol man had an answer for this.
Adam
First Name: Adam
Last Name: Doleshal
Re: Border patrol
Post by Adam » Tue Mar 26, 2024 12:56 pm
When you substantially change the outside diameter and/or width
Of your steer tires, you have to make appropriate changes to the caster & toe.
Re: Border patrol
Post by Rich Eagle » Tue Mar 26, 2024 2:06 pm
The radiator looks like a '28-'28 Model A. The hood, cowl gas tank and windshield may be Model A also. It's quite a design project.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Border patrol
Post by Rich P. Bingham » Tue Mar 26, 2024 4:07 pm
I caught the model A radiator, but thought the cowl was probably ‘26-7. I believe you’re right, Rich - that looks to be model A too. Can’t make it out clearly, but the dash cluster could be late ‘30-‘31 ?? Comfy seating ! :lol:
Get a horse !
Re: Border patrol
Post by John kuehn » Tue Mar 26, 2024 8:07 pm
Is the steering column from a T? It’s been mentioned but the steering on the car must have been tough. The bigger wheels and tires sure wouldn’t have been easy to turn without a modification somewhere in the front end. But they might have had to live with it.
Re: Border patrol
Post by Allan » Wed Mar 27, 2024 1:53 am
I missed the A model connection. If it is an A model, the steering will be much less compromised than a T model.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Border patrol
Post by Rich P. Bingham » Wed Mar 27, 2024 9:31 am
It’s a puzzle for sure Allan, but what is visible of the engine is definitely model T.
Get a horse !
