Re-babbitted connecting rods
Gene_French
Topic author - Posts: 1049
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
i have several single connecting rods ... all are re-babbitted and X oil grooves are cut and caps and rod webb drilled , all with laminated shim set inplace for final fitting ... sizes are 2 standard , 2 -.010" and 1 -.020 " diameters ... single rods can save a tour ... i also have a set of -.010" diameter rods that are listed on another advertisement ... will add photos later when i am able to re-size for this site ... price per rod is $60 + $17.10 postage in lower 48 states ...actual postage outside this area ...Gene French 970-581-2808 or email gfrench1953@hotmail
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Re: Re-babbitted connecting rods
a spare connecting rod is good insurance , not pleasant to change out a bad rod along the side of the road , but it is not pleasant to sit out an event either ...
Gene_French
- First Name: Gene
- Last Name: French
1 minus .020" rod sold ... thanks MTFCA
