Welded rods with an A crank
Bruce Compton
Topic author - Posts: 670
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I have a very nice 1913 Canadian block (three digit Canadian number) that has had a Model A crank installed. It also has a reground cam, adjustable and later valves and new 0.060 pistons and rings. Looking close at the connecting rods , it appears that someone welded T tops to A bottoms, The rods and crank are beautiful and the engine has run maybe 2-3000 miles and shows very little wear. The weld is right below the wrist pin hole and does not show any signs of fatigue, but I'm wondering if this is accepted and safe practice. BTW, the Main caps are the ones in Lang's catalog. A T buddy that has owned over 100 Model T's says it was a common thing to do, but I'm wondering why someone would not just modify the top of a stock A rod (bronze bushing with retaining clips)?? I believe that A rods and T rods are both 7" C-C. Any comments???? Thanks in advance. Bruce
1915ford
- Last Name: Cameron
- * REQUIRED* Type and Year of Model Ts owned: 1909touring 1915 touring
Re: Welded rods with an A crank
Was on a tour years back where a rod broke and grenaded a guys block. Tour over. T rods welded to a rods same as what you are describing. Even before seeing that i just think that trusting a welded rod is not something i would want to try with a block i care about. Especially if you don't know who, or how the welding was performed.
Kevin Pharis
- Last Name: Pharis
Welded rods are a quite common reality of A crank motors in the pre SCAT crank world. The A rods are 7.500” center distance and require a special piston if not shortened. The special A rod pistons are notorious for pumping oil, and the T tops allow standard piston choices. I’ve made up several sets of shortened A and hybrid T/A rods, and choose to box the rods for additional strength. Welding near the wrist pin is typical
Les Schubert
- First Name: Les
- Last Name: Schubert
Related but not, there were cast aluminum rods available for the A crank in a T block. I actually own a new set and a set of the bearing shells.
Sorry for the diversion!
Bruce Compton
- First Name: Bruce
Les, are they for sale? Bruce
- Last Name: Hatch
Buick 3800 V6 pistons will work. Need special bushings for A rods.
Brian Cress
- First Name: BRIAN
- Last Name: CRESS
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
Dan, are the Buick 3800 pistons "deck height" at TDC, or do they rise above the block like a stock T or A piston?
- Last Name: Hatch
Flat top pistons.
Brian Cress
- First Name: BRIAN
- Last Name: CRESS
Thank you for clarification.
AndyClary
- First Name: Andrew
- Last Name: Clary
So the Buick pistons work but you have no compression?
Andy
Andy
Kenny Edmondson
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
The Buick pistons work great. There’s a little protrusion above the deck.
- Attachments
- IMG_0065.jpeg (17.2 KiB) Viewed 2024 times
Brian Cress
- First Name: BRIAN
- Last Name: CRESS
Thanks for the picture Kenny.
