Speedometer
Topic author - Posts: 36
- First Name: Gregory
- Last Name: DeKeyzer
- * REQUIRED* Type and Year of Model Ts owned: 1923, aka Dust Bowl Special, very low mileage original 1915 roadster & an IKEA truck (IKEA because I have to put it together...)
Speedometer
What kind of grease, (if any) do you put on the speedo gears on the drive wheel. I can argue none, given the fact that grease will hold dust and turn the goo into a grinding compound, but hey, what do I know?
Re: Speedometer
I don't use grease there and agree with what you say as far as reason not to.
Re: Speedometer
Plus the gears are iron & fiber. No friction
Re: Speedometer
My guess is the smaller fibre gear is sacrificial. As they wear they can be easily replaced.
