Cylinder Head Marked "WHITE" over K_R
RVA23T
Last Name: C
Post by RVA23T » Sun Apr 07, 2024 9:48 am
Anything special about a head marked "WHITE" and under the white stamping, is a K_R ? This is on my engine and I noticed it while the head was off to look at how I'm going to address bad exhaust valves, as well as rot/corrosion at the head bolt hole and the water jacket between 2 & 3 along with 2 cracks radiating from the #3 exhaust valve seat. I have another better block that I'm going use but the head markings caught my eye.
KR and WHITE C.Head KR.jpg (54.77 KiB) Viewed 1015 times
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Cylinder Head Marked "WHITE" over K_R
Post by Jack Putnam, in Ohio » Sun Apr 07, 2024 11:55 am
The stamping WHITE may have been done by an engine shop to identify who owned the head. It means nothing as far as ford identification.
You need valve seats to fix that crack. That may not be the only crack. #2 & 3 usually crack.
RVA23T
Last Name: C
Post by RVA23T » Sun Apr 07, 2024 12:27 pm
Thanks i was thinking machine shop markings but in the T world you cant be too sure. The interesting part is the 2 marks KR first and White over top of kr.
The block is nothing special and is not original to the car and I have another block here that is better so I'm just gonna switch it out.
Post by TXGOAT2 » Sun Apr 07, 2024 2:33 pm
Some companies would mark their fleet cars, stamping ID into blocks, axles, frames, etc. The Prairie Oil & Gas Co did that back in the T era.
That valve looks to be well-done.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Apr 07, 2024 3:16 pm
Looks like Mr. White, didn't want to "lose his head".
