Got another T today
Topic author - Posts: 120
- First Name: Michael
- Last Name: Stroz
Got another T today
Just picked up a '27 touring that has some nice wire wheels and a Ruckstell that will be swapped into my coupe, and I'll put the wood wheels and original rear from my coupe back in this. Looks to be probably 95% complete, but it's in pieces, and is gonna need some metal work and paint. I'll post some more pictures soon, and I have a couple questions, but I'm probably going to sell it after I make sure the engine is solid, if anyone happens to want one. Would be excellent to cut down into a shop truck or racer, or restore
- Last Name: Stroz
Re: Got another T today
I saw it had this oil line that looks aftermarket, does anyone know what this is, or if I can maybe adapt this to my '26?
It's in pretty nice shape aside from the body, I almost wonder if it isn't the original body to this frame-
- First Name: Joe
- Last Name: Bell
I have seen that oil line on a couple engines that came through looked like an interesting ideal for oil to the front with a hollowed bolt.
There are jillions of outside oil lines that lubricate the front bearings, but it's very unusual to see one on the right-hand side of the engine. They all work the same way. The flywheel throws oil up through the mag post hole, and some of it flows through the tube to a hollow bolt at the front end, where it goes down into the engine to lubricate that front bearing.
- Last Name: Stroz
Yeah I've seen a couple internal ones, and an external one or two, but this is pretty interesting. Should definitely be good for my motor when I go up steep hills! I'll get some pictures of some goodies I found in the bins of parts when I get home, there's some good bits and pieces
- Last Name: Stroz
Some of the goodies from the bins of parts:
I'd be happy to take that purplish lens off your hands - I have the mate !
- Last Name: Saylor
You can get the outside oil line kit from any of the parts vendors, Langs, Snyders, Chaffins, etc.
- Last Name: Stroz
I did notice that, and it does seem to be a fairly close copy of this, but I didn't realize this was an original accessory you could get. Hadn't seen this before
- Last Name: Stroz
Safe and sound in its new home for the time being. Next weekend I'll go prep the Ruckstell for the swap and see if I can't get the engine running, then the weekend after I'll drive my coupe down, swap axles, and drive it home
The mag post pickup I have seen before, and it is available today from the parts houses. Yours has an oversized tube when compared with the ones now available. I have never seen one with the front connection made to the generator mount. It looks like it might be a replacement casting, complete with strengthening rib and custom made fittings for the tube and its connection. If that is the case, it should be easily transferred to you other car.
- Last Name: Stroz
As far as I can tell, the casting is original. It actually just replaces the lower bolt holding the casting to the block with one that has a hole drilled through it and a fitting on the end for the copper line to hook to. I should have taken better pictures before I installed it this morning, it's a pretty slick setup, and appears to be stronger and should have more flow than the similar kit I see on the Lang's websiteAllan wrote: ↑Sat Apr 20, 2024 8:52 pmThe mag post pickup I have seen before, and it is available today from the parts houses. Yours has an oversized tube when compared with the ones now available. I have never seen one with the front connection made to the generator mount. It looks like it might be a replacement casting, complete with strengthening rib and custom made fittings for the tube and its connection. If that is the case, it should be easily transferred to you other car.
