Coil hardware question
Topic author - Posts: 112
- First Name: Jim
- Last Name: Sarc
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
- Board Member Since: 2023
When replacing the coil top hardware can someone tell me where the 2 fiber washers go in the assembly process? The old coil I disassembled did not have them. I assume they are insulating washers.
- Last Name: Jablonski
Re: Coil hardware question
Are you referring to the metal top coil, or the wood top coil?
The two fiber washers are used under and over the bridge at the adjustment screw. I generally only use one under it.
- First Name: Jim
- Last Name: Sarc
Thanks Mark. That’s what I thought.Mark Gregush wrote: ↑Fri Apr 26, 2024 3:13 pmThe two fiber washers are used under and over the bridge at the adjustment screw. I generally only use one under it.
This Ford diagram depicts the details for what and where point mouning hardware should be installed on the Williams KW Ford ignition coil.
- Attachments
- Coil Sketch SK-2202.pdf
- (1.24 MiB) Downloaded 72 times
- First Name: Jim
- Last Name: Sarc
Thank you Ron.Ron Patterson wrote: ↑Sat Apr 27, 2024 11:43 amThis Ford diagram depicts the details for what and where point mouning hardware should be installed on the Williams KW Ford ignition coil.
- First Name: Chris
- Last Name: Barker
I agree with Mark; I find that the coil is best set up with just the fibre washer under the contact plate, above the coil spring.
And then TWO nuts above, locked.
I got this sketch out of JPG format so it is easier to print.
