Take-Apart Spark plugs
Topic author - Posts: 116
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring, 1925 Roadster
I have become the custodian of probably a couple hundred vintage spark plugs. I actually think they are a bit fascinating because of how many different companies had their versions of the same thing. I was looking through them today and decided to take (I should say attempt) a few apart to see if I could clean them up. Some of them look like they were part of an archeological dig but a little time on a wire wheel, torch and Kroil quenching I did get a few apart. Not much to go wrong with them once the carbon is cleaned out and no obvious porcelain issues. I cleaned up 4 champion X and bench tested them successfully. Decided to check them under compression so I swapped out the plugs in my 22 with my latest restorations. Took it out for a 5 mile spin and it ran great! Just wondering if anyone else runs restored originals in their car? The way I look at it I should never have to buy another spark plug!
Kind Regards
John
1922 Touring "Tinker"
1925 Roadster "Pops" (Pile Of Parts)
Martin, Ohio
John
Martin, Ohio
- Last Name: Hatch
Re: Take-Apart Spark plugs
That is all I have ever used.
- Last Name: Humble
I run 100 year old Champion plugs but have never taken them apart to clean. I suspect the take apart feature was probably just necessary for production.
- First Name: William
- Last Name: Vanderburg
I run original Champions in mine. I take all the ones I buy apart, clean them, make the electrode flat and gap them at 1/32nd of an inch.
William L Vanderburg
1922 Center Door Sedan
Sure. Champion X (much cheaper than new), Splitdorf, and others. This page may be of interest to some:
https://dauntlessgeezer.com/DG95.html
- Last Name: Jablonski
Good old Edison number 14 's, gapped at 0.025".... Same set used the last 24 years.
- Last Name: Humble
My unrestored 1924 runs with its original to the car Ford script Champion plugs.
Jeff, that is certainly the right style of plug for 1924. But how do you know it has never been replaced?
- First Name: Terry
- Last Name: Bond
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Would enjoy seeing photos of some of the more interesting and unusual plugs in that load. I've been collecting them a long time and am always looking for one I don't have.jwrightjr wrote: ↑Sun Apr 28, 2024 6:18 pmI have become the custodian of probably a couple hundred vintage spark plugs. I actually think they are a bit fascinating because of how many different companies had their versions of the same thing. I was looking through them today and decided to take (I should say attempt) a few apart to see if I could clean them up. Some of them look like they were part of an archeological dig but a little time on a wire wheel, torch and Kroil quenching I did get a few apart. Not much to go wrong with them once the carbon is cleaned out and no obvious porcelain issues. I cleaned up 4 champion X and bench tested them successfully. Decided to check them under compression so I swapped out the plugs in my 22 with my latest restorations. Took it out for a 5 mile spin and it ran great! Just wondering if anyone else runs restored originals in their car? The way I look at it I should never have to buy another spark plug!
Thanks,
Terry
- Last Name: Strange
I have a few Bethlehem "Five Point" spark plugs with four ground electrodes surrounding the single center electrode. The porcelains come in two styles, "fat" and "skinny". Both styles have 1/2 inch pipe threads.
