What are these gears?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri May 17, 2024 8:25 pm
Last Name: Tannehill
Re: What are these gears?
Post by JTT3 » Fri May 17, 2024 8:38 pm
Sort of resembles the gears in a plunger horn.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri May 17, 2024 8:42 pm
Guessing on the size of the gears compared to the metal washer. Could they be speedometer gear that's mounted on the front wheel bracket that mates with larger steel gear mounted on wheel hub ? .... Metal or fiber ?
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri May 17, 2024 9:00 pm
Metal 1/2" thick, 1-1/4" dia.
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Post by flatbroke3 » Sat May 18, 2024 11:18 am
oil pump gears
Post by Original Smith » Sat May 18, 2024 12:15 pm
Steering gears?
jab35
Last Name: Bartsch
Post by jab35 » Sat May 18, 2024 1:47 pm
I'm with Harold. On gear in each pair has a keyway
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat May 18, 2024 4:38 pm
For Model A?
