What are these gears?
Topic author - Posts: 1426
- First Name: Keith
- Last Name: Townsend
- Last Name: Tannehill
Re: What are these gears?
Sort of resembles the gears in a plunger horn.
- Last Name: Jablonski
Guessing on the size of the gears compared to the metal washer. Could they be speedometer gear that's mounted on the front wheel bracket that mates with larger steel gear mounted on wheel hub ? .... Metal or fiber ?
- First Name: Keith
Metal 1/2" thick, 1-1/4" dia.
- First Name: harold
- Last Name: musolf
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
- Board Member Since: 2010
oil pump gears
Steering gears?
- Last Name: Bartsch
I'm with Harold. On gear in each pair has a keyway
- First Name: Keith
For Model A?
