identify these doors
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sun May 19, 2024 3:13 pm
i have these 2 doors from a bulk purchase of model T parts ... was told these were from a model T sedan ... they will be for sale cheap , since i have no use for them ,BUT, i need to know year and model ... they measure 47 1/2" height by 24" width , the window is 19" by 19" ... the 1 door is very good the other has rust out on the bottom as seen in picture ...price is $100 for both doors ... must be picked up here in Nunn, Colorado ...( NO SHIPPING)...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
First Name: Gene
Last Name: French
Re: identify these doors
Post by Gene_French » Tue May 21, 2024 8:51 am
can anyone identify these doors ... was told that they were Model T Sedan ... what year ?
Last Name: Wrenn
Post by TWrenn » Tue May 21, 2024 9:11 am
I'm gonna guess 26/27 Gene
Post by John kuehn » Tue May 21, 2024 1:09 pm
Metal framed doors came out about early 25. The 25 Coupes had them but not sure if the sedans did. Looking at the door fronts they are hinged at the front. The coupes had the lock on the passenger and the drivers side didn’t have one. They very well could be for the 26- 27 T’s. My opinion is the came off the front of the car since they are a pair.
The door lock was placed only on the passenger side for some reason. Maybe the right hand drive Fords were different? But that’s another question!
Here’s an earlier post with some information about the closed car 24-27 doors. Bruce McCalley’s metal door information is in it using the factory part numbers. It’s kind of surprising! http://www.mtfca.com/discus/messages/25 ... 1351792740
Check it out.
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Tue May 21, 2024 2:23 pm
Hi Gene, I have a '27 Fordor and by the original engine number it was made in mid October, 1926. I just measured the front doors and they are 47 1/2" high at the highest point. Please note that the top of the doors taper from the front to the back and I measured the height at the highest point. I measured the width just below the belt line moulding and it is 24 1/4 ". I can't tell from the pictures you posted, but my doors have BUDD stamped on the inside just below the window opening and above the window winder handle hole. My Fordor is an original body with all original wood and the doors shut perfectly.
I hope this helps.
Keith
micshotrodgarage
First Name: michael
Last Name: miller
* REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Post by micshotrodgarage » Wed May 22, 2024 1:32 pm
Good information; I have a pair of these too. I can say what they are not ... 1926-27 coupe/sedan
Post by John kuehn » Wed May 22, 2024 6:08 pm
I have a 24 Coupe with wood framed doors. They measure 47 1/4” x 24 3/16”.
At a quick measurement I measured what Gene did. I did it again and took my time and remeasured what I posted. As mentioned in the my earlier post with the info Bruce McCalley put together the part numbers seem to be the same. The metal framed doors appeared in 25 so they may work for 25-27 T’s. And probably for the Coupes.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu May 23, 2024 10:10 am
thanks for the replay ... i will re-measure these doors to see if they are tapered ... it was thought that they came from a 4 door sedan ... anyway , they are for sale CHEAP ... i will have them at the swapmeet at the Adams county fairgrounds June 8th....Gene French
