Roadster upholstery question
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU (in progress)
Post by fordt » Tue May 21, 2024 4:59 pm
When finishing out/fastening the seat side panels, do you chamfer down the tack strip to meet the body panel armrest plane? Then slide the extra material over the tack strip and between the metal armrest side?
Re: Roadster upholstery question
Post by Original Smith » Tue May 21, 2024 6:45 pm
Where is the end cap? You failed to mention the year!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue May 21, 2024 6:49 pm
Looks like 26/27 roadster to me. Wish I could help but never got past the horse blanket phase with that car
Last Name: Strange
Post by CudaMan » Tue May 21, 2024 7:42 pm
Post by DanTreace » Tue May 21, 2024 9:32 pm
Yes, taper the tack strip, original wood tack strip was also tapered. Used that plastic strip on my '27 touring and did the same like factory, taper the edge down. The Improved open cars didn't use an end cap. Just finish off with Hidem Welt and a end trim nickel fastener.
Then fold under the leading edge of the upholstery about 3/8" to 1/2" to align with the metal edge of the body.
This install was without a top at the time, otherwise the Hidem is over the top cover edge.
Uphol side pad rollover large1 (550x367) copy.jpeg (41.19 KiB) Viewed 1991 times
Original runabout wood is tapered.
fordt
First Name: Rob
Last Name: Trippet
Post by fordt » Tue May 21, 2024 10:19 pm
Sorry about the year omission, but I figured the little metal rolled armrest piece by the door was pretty specific… Thanks for that first picture Dan!
rnkugel
First Name: Reuben
Last Name: Kugel
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Post by rnkugel » Tue Sep 03, 2024 3:07 pm
Rob. Quick question on the material in the pictures on your original post. I need to redo the front bottom on my 15 Touring, and that material is what I'm looking for. What is the material called (I know it is vinyl, but is there a name for the texture) and where did you obtain it? I have looked into a number of the T suppliers and find nothing. Thanks much.
1915 Touring
1926 RAJO Speedster
