Viton needle for Holley S Carburetor
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Post by Rod » Wed May 22, 2024 10:50 am
Does anyone have a source for a Viton tipped Needle? It’s for a 1913 Holley S carburetor. It measures 7/8” long by 1/4” wide. I don’t need the seat, only the needle. Also any gaskets out there?
Mark Nunn
Last Name: Nunn
Re: Viton needle for Holley S Carburetor
Post by Mark Nunn » Wed May 22, 2024 1:21 pm
Have you checked with Scott Conger? I don't know if he makes needles for the S but it is worth asking. Search for him using the "Extra Quick Links" button above right.
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Thu May 23, 2024 6:23 pm
No R in Viton.
Viton rubber is a type of Fluoroelastomer that has a highly unique molecular structure and composition. Manufactured from a combination of hexafluoropropylene (HFP) and vinylidene fluoride (VDF), resulting in material with exceptional chemical resistance, high-temperature stability, and excellent mechanical properties.
When I worked for Chrysler back in the 70s there was a recall that was related to them not using Viton in an accelerator pump instead of rubber that cost them millions.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Post by Steve Jelf » Thu May 23, 2024 9:51 pm
If my NH experience is any indication, Viton tip needles sometimes stick. That's why I prefer original type needles. If Scott makes a float valve for your carburetor, that's the way to go.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Thu May 23, 2024 10:13 pm
Ditto, those tips tend to hang for some reason.
