applying Spar varnish to firewall
Topic author - Posts: 17
- Last Name: Koonce
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Roadster, 1927 fordor
I found a post on this forum a couple of years ago about applying thinned Spar varnish to the firewall with a cloth, and it worked great. I want to do it again for another car but I can't remember if it should be a 50/50 percentage or something else. Also, I can't remember if I used turpentine or mineral spirits the first time. Recommendations welcome!
- First Name: Adrian
- Last Name: Whiteman
Re: applying Spar varnish to firewall
Hi Frank, I would suggest using the thinners given on the varnish tin as different manufacturers can use different bases. Try the thinning ratio on a bit of scrap wood and see what works for you.
Cheers
See this post as well: https://www.mtfca.com/discus/messages/1 ... 69404.html
and this one: https://www.mtfca.com/phpBB3/viewtopic.php?t=23013
Cheers
Penetrol is a product made to thin paints and extend brushing time to allow even coating. You just need to check that it is compatible with the product you want to use.
- First Name: Rich
- Last Name: Bingham
What Allan said. Urethane varnishes don’t thin well and are best used at package consistency. They don’t behave like the natural resin long oil varnishes of yore. Any road, a new-fangled foam brush would be a far better applicator than a rag.
Get a horse !
- Last Name: Koonce
Thanks to everyone who responded to my question about using Spar varnish. Much appreciated!
