I built a thing….
Will_Vanderburg
Topic author - Posts: 943
- First Name: William
- Last Name: Vanderburg
I built a thing….
Not “exactly” to plan but close enough
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
Re: I built a thing….
Improved. LOL. I forgot two pieces.
Well done William. Now all you need is a castor on each corner.
- Last Name: Humble
Looks like a strong and stable stand.
Whether "castored" or stationary, make sure it's high enuf off the floor to get your engine crane legs underneath it.
Nice looking cradle, if you get time, maybe you could post dimensions of the various pieces parts? I just might copy it before you copyright it!!
That’s a good call about the height and the castors. I have a feeling Will hadn’t got around to it yet.
Will_Vanderburg
It’s from a set of plans published by John ReganTWrenn wrote: ↑Sat Jun 01, 2024 10:18 amWhether "castored" or stationary, make sure it's high enuf off the floor to get your engine crane legs underneath it.
Nice looking cradle, if you get time, maybe you could post dimensions of the various pieces parts? I just might copy it before you copyright it!!![]()
Thanks Will. I'll look into it!
